P1320- Ignition Timing Retard Insufficient?
Old Apr 2, 2010 | 05:34 PM
2kvette's Avatar
Question P1320- Ignition Timing Retard Insufficient?
Had the code identified.......
Does anyone know what this is? What causes it? And is this something that could negatively effect my car and should take it to the dealer? Thanks!
Old Apr 2, 2010 | 05:54 PM
tephra's Avatar
FTM:
After starting the engine in the cold state, the ECM retards the ignition timing to early activate the catalyst by letting out the high temperature exhaust gases.
Check Conditions
•Under the ignition timing retard control.
•Engine coolant temperature is between 7°C (45°F) and 36°C (97°F).
Judgement Criteria
•For 10 seconds, the difference between the basic ignition timing and the target/specified ignition timing is 3°CA or less on average during the retard control.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are
•The thermostat is faulty.
Since you have a tune you will need to do some diagnosis yourself before taking it to the dealer...
Old Apr 2, 2010 | 06:34 PM
2kvette's Avatar
You da man! Thanks!!
Old Apr 2, 2010 | 06:54 PM
2kvette's Avatar
I have NO issues with the running of the car even though it keeps throwing this code. 2 questions.....
It seems that many others have had this code. There is a dealer reflash that is supposed to solve this problem.
1. Will I have any DAMAGE if I just ignore this code and don't get it resolved?
2. If I did get the reflash from the dealer..... What will it do to my Ecutek Tune that I already have?
Thanks!
Old Apr 2, 2010 | 06:57 PM
tephra's Avatar
if the thermo is stuffed then yes you should get it fixed asap...
most likely the dealer will just clear the code before doing anything - you should do the same...
1) maybe
2) the dealer will just flash over it, so backup your tune first, flash back to stock, take it to the dealer, then flash the ecutek back on...
Old Apr 2, 2010 | 07:31 PM
jeromski2003's Avatar
i had this code before popping up once a week (i have the dealer reflash already)....then i take it to the dealer, they reflash again and its been 3 months since then it never went back (knock on wood)
Old Apr 2, 2010 | 07:32 PM
tephra's Avatar
do u know the b4 and after romid's?
Raceghost
Jun 9, 2016 06:27 PM
wolf213
May 16, 2010 04:43 PM
importjake00
10
Jan 30, 2008 04:31 AM
noriceoz
Lancer Engine Tech
14
Nov 7, 2004 05:43 PM
