Supporting Fuel Mods For FP Red
Old Apr 18, 2010 | 04:54 PM
mirXa's Avatar
So i am contemplating an FP Red install on my X however wanted some input from you guys as to what size injectors and which fuel pump would be sufficient. Fuel rail? Fuel Pressure Regulator? Would an intank Walbro 255lph be more than enough or should i be looking at something like the AMS inline fuel pump setup or the Buschur Double Pumper? Overkill? List of current mods listed below. Target HP is 450ish..I am guessing this topic has been beaten over here again and again.... but any help from you all would be welcome!
thanks & cheers!
AMS FMIC
AMS Upper & Lower IC Piping Kit
AMS Intake
AMS Widemouth Downpipe
AMS Test Pipe
Full Race Pro Stock Manifold
Old Apr 18, 2010 | 05:57 PM
Clue4488's Avatar
I see you have a ton of AMS part already.
I just got thru with some new parts, and it looks like we have the same setup.
AMS has a great inline fuel pump system, fuel rail, and you can go with 800cc or 1000cc injectors. I went with 800cc injectors, but if you plan on upping the HP in the future, i would get the 1000cc.
Gonna need a new clutch. i went with the Exedy Stage 2 clutch, with an ACT flywheel.
-Andre
Old Apr 18, 2010 | 07:52 PM
HiI'mDustin's Avatar
E85 or pump?
Old Apr 18, 2010 | 07:56 PM
saytheb's Avatar
I am running DW1000s with Blaqops single in-tank pump kit with stock fuel rail.. FP Red with E85, currently I am nearly maxing the injectors. I am looking to throw on an in-line 255 in addition to the in tank and new FPR, see what happens then.
I would say a single pump with 1000CC injectors on the red should put you nicely for 91/93 IMHO.
Old Apr 18, 2010 | 09:32 PM
mirXa's Avatar
Originally Posted by HiI'mDustin
E85 or pump?
pump 93
Old Apr 19, 2010 | 06:08 AM
get 1000cc injectors and do a fuel pump...there really isnt a need for a "fuel kit" unless you are running E85 or something bigger than a FPred
Old Apr 19, 2010 | 12:27 PM
Evo a Mula's Avatar
black ops double pumper is good.... but get at least 800cc or 1000cc injectors or a regular walboro fuel pump
Admin2304
Mar 28, 2017 09:17 AM
51
Oct 18, 2016 12:43 PM
Grif
Mar 12, 2012 07:29 AM
churchja
17
Nov 16, 2010 08:15 PM
reyrey
22
Mar 25, 2009 08:38 PM
