boost gauge help!
Old Apr 21, 2010 | 04:47 PM
samul said's Avatar
boost gauge help!
I'm currently using an AEM digital boost gauge and starts off with -30psi to 35 psi..and recently my cars been sitting at -30psi at idle and has a hard time passing -14psi...Do you guys think it's the hose ripped or do I have a boost leak? Thanks.
Old Apr 21, 2010 | 05:18 PM
cpunlamd's Avatar
Hard to say. Were you able to build boost on this gauge before?
Old Apr 21, 2010 | 05:44 PM
dreyfus14's Avatar
Sounds like the gauge is bad....what is the gauge reading with the key on and engine not running?
Old Apr 21, 2010 | 06:26 PM
wiretap's Avatar
If the car is running normal and hitting boost fine, it's probably a bad gauge, or you tapped into an incorrect hose.
You should be around 20 in/Hg at idle.. then go into positive boost, obviously, when you accelerate hard.
Old Apr 22, 2010 | 10:50 AM
samul said's Avatar
My gauge was running 18lbs of boost before and now it goes only upto 8lbs of boost and struggles to go even higher..when my car is on (not engine running) it sets as 14-16.
Old Apr 22, 2010 | 10:57 AM
wiretap's Avatar
Replace the gauge. (or sender unit?) I'm not sure how the AEM digital gauge is setup.
v8<turbo4
Oct 10, 2013 07:38 PM
sti45007
Dec 1, 2011 08:32 AM
rawburt
Apr 30, 2009 10:01 AM
Dapper Dan
Mar 16, 2008 08:45 PM
krazirob
Jul 24, 2006 05:07 PM
