Can you do rod bolts without taking the ...
Old May 3, 2010 | 03:06 AM
tephra's Avatar
well the 4b11 rods bolts are actually bolts - rather than threaded dowels..
so no pressing involved..
i think anyway
Old May 3, 2010 | 04:27 AM
MarkM's Avatar
do the rods!!! My bolts were fine............
Old May 3, 2010 | 06:42 AM
murlo26's Avatar
^Yea that, and actually the piece of rod that went through my block wasn't the rod bolt side.
Old May 3, 2010 | 07:15 AM
mlomker's Avatar
Originally Posted by tephra
well you can do rod bolts WITHOUT taking the head off... just the oil pan and windage thingy
Yeah, the oil pump sprocket has to be moved to gain access to one set of the rod bolts but otherwise it is straightforward. There are pics of this in the service manual.
i have no doubt that a full drop-in would be harder than most peoples capabilities, but you know me - always like to try things myself
I know that my mechanic spent quite a bit of time carefully filing the rings. I hadn't realized how involved that is since I've never built a motor before.
Old May 4, 2010 | 02:02 AM
JED_POLAND's Avatar
Great topic.
I've been thinking of doing the rod&pistons since December.
I was even given a quite good offer on CPs+Manleys here.
BUT my problem is that I believe untouched engine is untouched engine.
Do you know what I mean?
I do not know about the U.S. but here in Poland you do not get any warranty on the labour whatsoever.
It means if the engine blows out even around the corner it is on you not the workshop!
Old May 4, 2010 | 02:24 AM
hotdog's Avatar
I think you'd be hard pressed to find any shop, anywhere, warranty their parts and or labor on a modified motor. I've never heard of a shop warrantying anything.
Old May 4, 2010 | 06:24 AM
murlo26's Avatar
^correct, unless it blows up before it leaves the shop, lol.
Old May 4, 2010 | 06:34 AM
JED_POLAND's Avatar
Well, it is hard to understand, though.
Because it could be a poor work and why would I have to pay for that?
Old May 4, 2010 | 06:36 AM
murlo26's Avatar
typically it would have lots of problems on initial start up or the dyno so then it would still be at their shop.
That is why i said as long as it blows up at their shop
That is one reason it is a good idea to have one shop do all of your work, so if something goes wrong you have a better chance of it getting covered partly or fully.
Old May 4, 2010 | 07:30 AM
mlomker's Avatar
You do have to pick your shop carefully...it's all a part of the modding game. I had a problem with my build but it was in their shop so they're taking care of it.
Old May 4, 2010 | 08:55 AM
powersteer's Avatar
You can 100% change the rod bolts juz be removing the oil pan, but you will need to remove the head if you wanna change con-rod
Old May 4, 2010 | 10:55 AM
H Jensen's Avatar
If i'm not going to be pushing more than 25psi and I wantto raise the rpm limit to 8500-8800 will rod bolts be fine or will I need rods and pistons aswell?
Old May 4, 2010 | 11:01 AM
mlomker's Avatar
Nobody can answer that for sure. You can try your luck but it's probably cheaper to do drop-ins than fix a thrown rod.
Old May 4, 2010 | 11:10 AM
H Jensen's Avatar
Point taken.
Old May 4, 2010 | 11:29 AM
murlo26's Avatar
It is not probably cheaper it is cheaper to do drop ins than fix a thrown rod, trust me.
