Turbo Spool Comparison Data
I was just at DB like an hour ago...mine won't be done until mid july at least.
We ordered all the parts today, shortblock will be here 1st week in july then they will start putting that **** together.
****ty pic...this camera needs a flash damn it!
OEM and building.
There are 6 OEM shortblocks coming to the USA soon and they are backordered. I have the 4th one coming, so it won't get to DB until the 1st week in July. But my fully built head will be done by then and my tranny. So they will just need to do the shortblock work and tune.
I am not going BBX anymore....something...bigger.
I have Dom 2. Typical mods on car. 411whp (93 pump gas and 29lbs boost). Full spool by 3800. No surge in 3rd gear. Some surge in 4th but little. Looking to upgrade to BBX full but do not see numbers yet better than 411whp on BBX. Awaiting someone to post numbers for BBX full.
Here is a thread with some data I did a couple years back on a DOM II
https://www.evolutionm.net/forums/ev...-lots-too.html
If I would have had known as much then as I do now about Mivec tuning I know it could spool faster.
I hope this helps?
Mitch
I hope this helps?
Mitch
Dominator 2, 3rd gear pull starting 2500rpm (could do some work on the 3-port solenoid to improve spool by like at least 100-200rpm... problem is Tephra v1 doesn't include the "wga 100% under this load" feature that is included in the evo8-9 roms)
2500------120-----5.3
2633------127-----6.3
2760------132-----7.0
2863------138-----8.1
2992------146-----9.6
3125------158-----11.5
3266------173-----14.0
3422------194-----17.3
3600------222-----21.5
3800------256-----25.6
3992------274-----27.4
4200------279-----27.7
Note that after 3500rpm the 3port duty cycle is 50% instead of 100% while the boost is still about 18psi... I should try keeping it 100% until 3700 or 3800 and see what happens...
