Evo X Blown Motor Out now...
Old Jun 10, 2010 | 09:05 PM
ZWingerRyRy's Avatar
Hmm its weird because they both baselined around the same for the stock evo 10s. But for those mods and psi...What a heartbreaking dyno. Owell itd be fun to say you make 420awhp and spank a 500awhp car. =]
Old Jun 10, 2010 | 09:07 PM
murlo26's Avatar
Exactly....i smoke crotch rockets a few times before the motor blew.
Old Jun 11, 2010 | 06:34 AM
DeatschWerks's Avatar
That sucks to see, murlo!
You'll be back, bigger and badder. Good luck.
Old Jun 11, 2010 | 06:36 AM
murlo26's Avatar
Thanks Chris...hopefully by mid july-late july so i still have some summer left.
Bigger/badder for sure...my new plans are probably going to require bigger than your 1300cc injectors
Old Jun 11, 2010 | 06:49 AM
Well...what can you do, eh?
Who knows, by then we might have something for ya.
Old Jun 11, 2010 | 07:00 AM
tsitalon1's Avatar
Nice VTA on that block Murlo, how can I get that woooosh sound on mine.
Seriously, good luck with the build and GREAT attitude by you. And PROPS for being a man and not reverting to stock to try and convince Mitsu it's a warranty issue. To many a$$holes do that and mess up folks with genuine warranty issues.
You pushed and the motor pushed back, no design flaw there!
btw, are the pics decieveing? I would of that the block walls were thicker than what's pictured.... 1/4" or so?
I'm sure your FICO is on the downward slide.
Old Jun 11, 2010 | 07:01 AM
murlo26's Avatar
Well the sleeves are pretty think, you are seeing the area around the crank that is thinner.
However the rod spun around the crank and did break off part of the sleeve.
Old Jun 11, 2010 | 07:05 AM
BriK's Avatar
Anxious to see the final product, murlo. It'll be interesting to see this stack up against mlomker's.
Old Jun 11, 2010 | 07:07 AM
murlo26's Avatar
I will have a few unfair advantages
Old Jun 11, 2010 | 08:41 AM
REVOlution86's Avatar
i say do what i did! go 2.2!
Old Jun 11, 2010 | 08:43 AM
murlo26's Avatar
2.2 isn't super necessary, and also it really skyrockets the price. The sleeves are only 500-800 probably, but the machining is like 1500-2k i think.
Here is what I am doing:
GSC S2 Cams
Manley Springs/retainers
+1mm Supertech Valves
ARP Headstuds
Port Polish head/resurface
OEM Headgasket
New OEM Shortblock
Drop out new OEM pistons/rods
Put in Manley Turbo Tuff I beam Rods
Put in Manley stock size pistons (on new OEM shortblock, their is no Glaze to break since it has never been run and they do a lot of machining, so this was the best option, to stick with factory shortblock)
Stock Sleeves and crank and main bearings(main bearings are awesome as long as you don't have an oiling issue)
Cosworth rod bearings
New injectors, probably ID2200's
New turbo....special one.
Edit: also doing upgraded diff pins while I am in there.
Old Jun 11, 2010 | 09:15 AM
E6-X's Avatar
killer in the making ... when is it gonna be completed ? i think i better look into at least new rods, rod bearings and arp studs.
Old Jun 11, 2010 | 09:20 AM
murlo26's Avatar
I am hoping for end of july at the latest...but you know how these things go.
Old Jun 11, 2010 | 05:28 PM
Arent the intake valves already to big for the engine already? But depends on your power output. Been quoted yet for the headwork for the oversized valves yet? And i dont think Supertech has finished the oversized seals yet.
Old Jun 11, 2010 | 05:33 PM
Evo a Mula's Avatar
wow that whole looks like a copy of mine lol good luck to you man
