Vibrant Performance / AMS O2 Sensor Spacer - Work for you?
Old Jul 15, 2010 | 12:00 PM
HybridKOOP's Avatar
I think I have a different problem from the start. P0140...
Old Jul 17, 2010 | 04:19 PM
Wicked X's Avatar
With this part you have to reset the codes and I run a AP with this and no codes what so ever once I cleared it with the ap.
Old Jul 17, 2010 | 04:38 PM
RaysEvoX's Avatar
If you dont have AP or a code reader, just go to auto zone or advance auto parts and have them clear the codes.
Old Jan 11, 2011 | 10:11 AM
Nauticabri's Avatar
this is designed to fix the p2096 cel correct?
Old Jan 11, 2011 | 01:15 PM
Wrex1977's Avatar
I have the Vibrant spacer on my AMS TP which I've had installed for the past week now. I started out with the medium spacer. The advice that AMS gave me was to start with the medium spacer and see if you throw a CEL. If you start with the smallest it might not read enough and throw a CEL. If you start with the biggest it might read too much and throw a CEL.
With the medium spacer in I throw a CEL for less than 1 day and it hasn't come back. I figure after I install the AMS DP I will get a tune which will help fix the issue.
Old Jan 11, 2011 | 02:31 PM
derekste's Avatar
this can be fixed by a simple ecu reflash.
Old Jan 13, 2011 | 12:45 PM
Wicked X's Avatar
works perfect for me. ive had on over one yr not one cel.
Old Mar 9, 2012 | 05:24 PM
MR Mitzi's Avatar
Sorry for bumping a dead thread but...
I just got the Vibrant O2 spacer, Opted to install with out the added restrictors... No CEL... Great so far.
However, I have it mounted on a HKS Exhaust, right after the Cat... and its so long its vibrating against the bottom of the car. I believe there is a O2 port on the Cat, but then the wiring is going to run long.
So far not its just a bad design... it could be alot shorter, but does work.
Old Mar 12, 2012 | 12:02 AM
Martinezusn's Avatar
when i installed my perrin donwpipe/hfc i also did get a cel but once i got thw vibrant 02 spacer and problem fixed . 2 years later and no problem
Old Mar 12, 2012 | 06:03 AM
01CBR929's Avatar
Vibrant o2 didnt work for me, unfortunately.
Old Sep 1, 2012 | 03:32 PM
lippy1306's Avatar
Vibrant o2 spacer worked for me. I'm running a AMS downpipe & HFC with a Perrin Catback.
Old Sep 1, 2012 | 07:13 PM
St1g's Avatar
have a 100cel cat and even with the vibrant spacer using the smallest hole it still throws the codes.
will try an elbow type later when i have time.
Old Sep 24, 2012 | 10:43 AM
Tech/Sales@EM's Avatar
I have a spacer that I took off a car if anyone wants to give it a try to see if it works. The car I took it off from had the O2 Sensors coded out so I no longer need it.
Old Oct 1, 2012 | 10:57 PM
bingas's Avatar
I have one on my Catless KIA haha with the mid spacer no problems. And I was running one on my Catless Evo X with the mid spacer no problems either.
nzevo8
Jan 14, 2016 04:30 AM
projekj
Apr 30, 2015 08:49 AM
pierceman
Oct 6, 2013 03:12 PM
Dawid5surowiec
Aug 2, 2013 06:31 PM
smokehim98
Jan 18, 2012 09:47 AM
