10K Modding suggestion
Hello
as the title says
my current mods are:
What I have in mind:
Thank you
as the title says
- AMS TB
- AMS UICP
- HKS EVC6
- HKS Spark Plugs
- FP RED ported with upgraded Wastegate Actuator
- Deatschwerks 800cc Fuel Injector Set
- Walbro 255L/HR Fuel Pump
- AMS FMIC
- AEM Cold Air Intake?? (will it work with sst w red??)
- SSP Evo X MR 500HP Upgraded Clutch Packs/Steels
- SSP Evo X MR Front Mount Trans Cooler Package with Deep Pan
- SSP Evo X MR Upgraded DCT seals
- TEIN Mono Flex with EDFC (Electronic Damping Force Controller)
- Kelford Stage 2 Camshaft with Valve Spring Set?? (Could someone please explain what other parts will I need to make them work! I absolutely have no idea about cams)
- Cusco Front Sway Bar
- Cusco Rear Sway Bar
- Cusco Type OS Front Oval Strut Bar
- Cusco Type OS Rear Oval Strut Bar
Thank you
this mostly applies to the 5-speed but it'll help you to review the Mellon Tuning EVO X Staged upgrade path http://www.mellontuning.com/index.ph...ex&cPath=18_52
If you are running pump gas without meth then I doubt you need the upgraded clutch packs yet. You can consult SSP on that but I should think you could get by with just the oil cooler if you wanted to save some money.
good kit costs 6000+
currently i have PF01 pads, Motul fluid and AMS lines.
I don't believe that the AEM will work with the FP turbos due to the larger 3" turbo inlet on their turbos, Cobb just came out with turbo inlet pipes for the FP series, this is the direction I would go regardless. Stock box and Cobb turbo inlet pipe, drop in filter. This will save you around $150 too.
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
44
Feb 28, 2007 02:08 PM
Gruppe-S
Aug 1, 2006 07:27 PM
