lost all power on interstate backfireing help please
Old Jul 9, 2010 | 02:53 PM
finallyaevowner's Avatar
filled up today so it could be bad tank of gas checked in line filter was clean and clear has any one else had this problems. after about 15 min of this i got these codes po171 system too lean; po134 02 sensor no activity bank 1 sensor 1; po133 o2 sensor circuit slow response bank 1 sensor 1 p2195 02 stuck lean
Old Jul 9, 2010 | 03:15 PM
there was a thread about a vacume line that had no clamp from the factory it had pictures od were it was located any one know were i can find that thread
Old Jul 9, 2010 | 04:08 PM
monkey_187's Avatar
yes right here
https://www.evolutionm.net/forums/ev...s-do-asap.html
Old Jul 9, 2010 | 10:11 PM
thx i was really hoping that was it but it was not. i was hoping someone on this site may have had the same problem. it acts like it is starving for fuel
Old Jul 9, 2010 | 10:17 PM
Mike Bones's Avatar
Perhaps your fuel pump relay? Still a black one?
Old Jul 10, 2010 | 12:32 AM
gripbox's Avatar
you should check all your connections, installs, boost leaks, popped-off hoses...anything of the like. try to see if you have any other hoses missing that's suppose to be on something. other then that, if you still have warranty, you should bring it to the dealer OR have someone experienced away from the dealer to check it out for you and diagnose the problem
Old Jul 10, 2010 | 08:48 PM
already changed to the new relay
Old Jul 10, 2010 | 08:58 PM
warranty gone a long time ago lol i have looked every thing over the best i can have found nothing like that thx for the ideas. would bad fuel cause those codes. i fuelled a few hours earlier noticed if felt a little hesitant then was ok about 90 miles later i was on the interstate and all of a sudden it was stalling and about 3 grand was all it would turn. anything over that it fell on its face. really felt like a fuel filter but it wasnt i have also checked all boost lines clamps ans vacume lines, fuel pump is working fine could it be a bad o2 senser when engine is cold could it cause it not to start, cause now it wont fire engine just cranks
Old Jul 20, 2010 | 06:37 PM
anyone have some more thoughts on this no shop near me i trust could a bad 02 sensor do this?
Old Jul 20, 2010 | 11:12 PM
AWDTerror's Avatar
Could be a number of things. Check your o2 sensor, the wires, connections, etc. Like stated before, swap the relay...just because you changed it doesn't mean it can't break.
Check for blown off or leaking coupler. Check all your connections to your fuel injectors. Check your pump install.
What did your AFRs read?
Old Jul 21, 2010 | 06:16 AM
Mojito's Avatar
Sounds like a bad O2 sensor.
Old Jul 21, 2010 | 06:44 AM
i put the old relay back in and no change and i am getting fuel. can a o2 senser cause a cold engine no to start
Old Jul 21, 2010 | 07:37 AM
SilverEvoX's Avatar
Do you have a wideband or can you post up some logs of what it's doing when it starts to fall on it's face. Depends on which o2 sensor it is. If it's the front o2 sensor, i.e. the important 1 then it would definitely cause all of the abovel listed problems. If you checked your fuel pump relay and check the FPR hose and make sure it didn't come off or rip then it sounds like the next logical step would be to check the o2's and then the connections to your fuel pump/fuel lines under the hood. Also how many psi are you running?
Old Jul 21, 2010 | 08:24 AM
mlomker's Avatar
I've had a couple P0133's recently. I looked up the replacement front o2 and apparently the front and rear o2's are the same. You could try swapping them. A bad rear 02 will throw a CEL but it won't keep the car from running.
Old Jul 21, 2010 | 10:39 AM
SilverEvoX's Avatar
Also on a side note, if it is an o2, its about $400 from the dealer...
