Clutch for high rpm/drag/dd
Hi chaps,
I would appreciate some advice from those in the know please, I have thought of carbonetics tripple as it will illiminate the pull style setup but was wondering if there are any other options such as tilton etc???
700+hp, 780lbs/min turbo, full head work, built short motor, drag use, high rpm use and daily driver.
Thanks
Thanks
nobody answers b/c if you're seriously building a 700+ HP car, with a turbo that flows 78lbs/min (what the hell are you putting on here, and when do you plan on it spooling???), then you should have some sort of idea of how to get that power to the ground. Or at least be paying a shop a hell of a lot of money, and they should know what to use. Or else you're full of it.
But on the off chance that you're actually doing this, I would talk to AMS about the exedy push style triple. IDK if I'd use a carbonetics...
Norris Designs offers a triple plate clutch for you...Sound like your building a beast of a car like ND's cars.
http://www.norrisdesigns.com/proddet...rod=evo-034512
or
Exedy Triple plate clutch
http://www.amsperformance.com/cart/e...lutch-kit.html
or
or
or
http://www.amsperformance.com/cart/a...lutch-kit.html
However I was wanting to hear of other options (superclutch, tilton etc) hence the post.
Thanks
Thanks
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
honda-guy
26
Feb 17, 2014 08:10 PM
