ETS intake with access port.
Old Jul 12, 2010 | 12:54 PM
Stevo-9's Avatar
I just got my ets intake installed. Is anyone running this with an access port? If so what map are you running? I love the intake but if I can't find support for it I may switch to the aem.
Old Feb 2, 2011 | 06:11 PM
HELPr's Avatar
I have the same issue. I cant seem to get a map that keeps the short term fuel trim close to zero :/
Old Feb 2, 2011 | 07:31 PM
sun_ice4's Avatar
Originally Posted by Stevo-9
I just got my ets intake installed. ...what map are you running?
I have the same question. I could only find this link where it was suggested to use just the basic map. But I'd like to know if there's alot of guys doing this, and if they are having problems or not.
https://www.evolutionm.net/forums/ev...-tune-ets.html
(Michael's post #6.) "A tune would be recommend to get all the power possible out of the setup. We have customers who use the cobb access port with basic maps. The good thing about our intake is it uses the stock MAF housing so you will not need to rescale on install. "
Old Feb 4, 2011 | 09:54 AM
HELPr's Avatar
I think that when Michael says the basic maps he is just refering to the OTS maps that cobb offers.
I have found that the COBB SF map works best for me, yet I still see counts all the way up to 10.5 on STFT this is usually when letting of the clutch and lightly modulating the gas pedal to begin moving. the LTFT stays at 0. I still see a ton of black smoke at high rpm at full throttle...
Old Feb 4, 2011 | 10:26 AM
Kracka's Avatar
I'd recommend using the Cobb SF maps as mentioned above, they should be pretty close.
Old Feb 4, 2011 | 04:04 PM
sun_ice4's Avatar
Aahhhh, yeah.. that does make more sense.
And thanks to you both for suggesting the SF map. Could I ask why you suggest that particular one?
Old Feb 4, 2011 | 04:09 PM
Kracka's Avatar
Cobb SF intake was designed to be compatible with stock MAF scaling just like ETS' was. I would assume the AEM is also very similar too, but I'd have to dig into the OTS maps to pull up the exact scalings.
Chenzo82
Aug 2, 2016 02:17 PM
03redtype-s
Dec 21, 2015 03:44 PM
hispanicpanic
May 25, 2013 09:55 AM
funks
24
Aug 14, 2009 02:53 PM
