UICP sound ?
Old Aug 17, 2010 | 10:08 AM
Lancerally_Mick's Avatar
UICP sound ?
Just Installed a nice Nisei 1pc Flat black.
When I accelerate, the normal turbo sound ( spooling ) form 2000 to 4000 is still there ( got an cone filter )
but then after 4000 RPM , a balloon sound ( when you have a birthday balloon and you let go the air streching the exit to make a high pitch sound )
and Its really loud ...
I retight up the T-clam and they really look ok, but it still does the same
Is it a normal sound ( I hope not cuz it sucks ) or I really need to tighten up those again ...
Old Aug 17, 2010 | 10:26 AM
1800bigk's Avatar
Not normal, has to be leaking from somewhere is my guess. Double check all connections.
Do you have a boost gauge, is it reading the same as before. If everything checks out then it could be your turbo going bad.
Old Aug 17, 2010 | 02:12 PM
Bob Evolved's Avatar
Sounds like when I had a nasty leak where the UICP connects to the intercooler, double check everything! I had to switch out those terrible clamps for T-bolts and the sound went away
Old Aug 17, 2010 | 09:17 PM
I retight all the t-clams again like a freak, crossing my fingers that I didnt bent a thing, and the nasty sound went away
Old Aug 17, 2010 | 09:54 PM
popdakebin's Avatar
I have the same thing going on. I think I need to redo it.
Old Aug 19, 2010 | 05:55 AM
Matruco3's Avatar
It's definitely a leak... I just installed mine last night and I got the same "balloon" sound.
I ended up having to re-tighten the T-bolt clamps by A-LOT. I was concerned that I would bend the pipes but it didn't happen and the sound went away.
My best mod so far!!
Old Apr 3, 2011 | 04:23 PM
robearralliart's Avatar
Sorry to bump a kind of old thread, but it is relavent.
I installed the DC Sports UICP for EVO X / 09+ RA
I went around the block, the Turbo sounds was LOUD. I knew something was not right.
Re-installed, tightened the couplings, and clamps, very tight. The piping should not move at all when it installed, very little give.
The sound is just a tad louder than stock. Turbo spool is somehwat quicker.
Good buy in my opinion for the money.
Note:
The DC Sports UICP Kit includes couplings for EVOX and 09+ RA. fits both intercoolers.
Charlie-Y
Mitsubishi TC-SST Discussion
Oct 19, 2016 09:04 AM
rjsdxm
19
Aug 7, 2007 02:01 PM
akinakin
67
Jul 26, 2007 05:50 PM
adotwhite
Apr 10, 2005 10:04 PM
