AMS CAI leads to water in LICP
Old Aug 18, 2010 | 12:45 PM
tjac357's Avatar
I searched and found little information on this topic. Here is my problem. I have a GSR with AMS CAI and JDM Mesh Foglight insert. I had my LICP off recently and found water in it. I know this isn't the best thing for my car and I'm wondering if anyone else has experienced this and if there is a way to prevent this from happening. I think I saw a cone style air filter cover that keeps water out a while ago, but I can't remember where from of if it helps.
Thanks
Old Aug 18, 2010 | 12:47 PM
Parikh1234's Avatar
hmm, thats concerning. I have the same setup. Def keep us in the loop if you find anything.
Old Aug 18, 2010 | 01:14 PM
CatalystGod's Avatar
Wonder if you can run a deflector from the mesh screen to to divert the water/debris somewhere else.
Old Aug 18, 2010 | 01:49 PM
SVPxTuRbO's Avatar
most cold air intakes that run down towards the bottom of a car will suck up water. Thats why in wet conditions your suppose to change it out or take it off.
Old Aug 18, 2010 | 02:24 PM
EVO X 6950's Avatar
true story
Old Aug 18, 2010 | 05:55 PM
RaysEvoX's Avatar
I have the same CAI. Ill have to take mt LICP off this weekend to see if I have water in there.
Old Aug 18, 2010 | 06:58 PM
Parikh1234's Avatar
before buying the CAI i talked to AMS and they said they have never had such issues. Would be interesting to hear their side of the story on this.
Old Aug 18, 2010 | 07:15 PM
charon2123's Avatar
Did you have any water in your intercooler as well? I had the AMS CAI and had no water in my LICP.
Old Aug 18, 2010 | 07:34 PM
RevLimiter's Avatar
you should take it off in wet conditions or you should get an Injen Hydro Shield, im pretty sure it would still fit the K&N filter.
Old Aug 18, 2010 | 09:21 PM
EndlessRed's Avatar
after i hydrolocked in my old car, i told myself i'm never buying another CAI again.
you can always run a bypass in the middle of the inlet pipe, but at that point you might as well go with a short intake.
Old Aug 18, 2010 | 10:07 PM
2010XMAN's Avatar
Got down and and removed mine as well. I dont have the mesh grill and thought about getting it and still would after reading this but I have zero water in the LICP.
My question is the air is sucked in, drove through the compressor thru the UICP into the FMIC and then rested into your LICP and your didnt notice a lack of performance? thats alot of water and a nice distance to travel. something is def not right
Old Aug 18, 2010 | 10:12 PM
ChrisBond1's Avatar
i believe injen make a hydroshield, which lets air through to the filter but not water.
http://www.injen.com/docs/products/listing.asp?pcc=rp
i hope this helps
Old Aug 18, 2010 | 10:21 PM
willyan1989's Avatar
I am really concerned about this also.
Myth #1:
It's a turbo car!!!! the water will vaporize in the turbo due to the heat!!! (True?)
Myth #2:
DUUDE stop driving your car right into the river!!! Your cold air intake needs to be submerged into water completely before getting a hydrolock!!!!1!!one (True?)
Question #1:
Would stock airbox cause the same problem? and what happen during a snow day? I don't want a hole in my engine block.
Experts!
Old Aug 18, 2010 | 11:03 PM
Bighec's Avatar
Lets think about this for a second. For water to enter your LICP through your CAI it must first pass through your turbo and combustion chamber. Water in your LICP is not caused by running a CAI. A hydro-locked motor could be caused by a CAI.
Old Aug 19, 2010 | 02:03 AM
2010XMAN's Avatar
Thats what I was getting at with all the path of the flows i listed besides combustion chamber but that was a pretty much known fact.
