GM 3 Port BCS vs. others
Old Aug 24, 2010 | 09:31 AM
Kiloalpha's Avatar
As far as BCS's go, what is everyone running. I was just going to get a Grimmspeed but I read the post comparing the Grimmspeed to the GM.
It is my understanding that GM has a plug n play version now. I have used google to try and find the GM BCS with no luck; who sells it?
Second question, for now I'm planning on keeping the stock turbo with pump; is it even worth getting a BCS?
Old Aug 24, 2010 | 03:06 PM
woodyqb's Avatar
http://www.szabaga.com/store/gmbcs.html
Old Aug 24, 2010 | 03:49 PM
Kiloalpha's Avatar
Ya i see they sell the adapter, but where do you get the actual GM BCS?
Old Aug 24, 2010 | 03:59 PM
Clipse3GT's Avatar
ebay
Old Aug 24, 2010 | 04:30 PM
Kiloalpha's Avatar
So if I bought this:
http://cgi.ebay.com/ebaymotors/GM-Bo...s#ht_624wt_841
and this:
I'd be set?
Old Aug 25, 2010 | 07:42 AM
ImsoevoX's Avatar
I got it right from Grimmspeed's site
http://www.grimmspeed.com/catalog/pr...eg1ikh57021k87
Please do take care to make sure you order the right fitment...I love this thing..it's amazing..but..you will need to get retuned if you plan on running it...
Old Aug 25, 2010 | 07:53 AM
Kiloalpha's Avatar
Grimmspeed seems to be the easy option as I can just make a single purchase and get a complete plug n play unit. However it appears that the GM unit is the better option.
https://www.evolutionm.net/forums/7977427-post122.html
https://www.evolutionm.net/forums/ec...ting-data.html
The GrimmSpeed (provided by SoCal Rally for testing) is very comparable in performance to the GM BCS. It opens very fast (3 ms vs 6 ms for the GM), but based on the scope signal, the valve bounces off the valve stop several times before settling into a full open position. (This is the only solenoid I've seen that does this.) The pressure variation vs duty cycle is very similar to the GM BCS. The only practical differences is that the GrimmSpeed bleeds off a little more pressure in the mid duty cycle range. This means a slightly reduced useful duty cycle range compared to the GM. The pressure swings from the solenoid opening and closing are a bit larger than the GM. This means that if you could see the WG flapper during boost, it would be oscillating a bit more with the GrimmSpeed vs the GM.
As a n00b, could these problems result in WG failure of some sort?
Old Aug 25, 2010 | 08:06 AM
Kiloalpha's Avatar
*deleted*
Old Aug 25, 2010 | 08:22 AM
mrfred's Avatar
Both solenoids are good. GM option is a little cheaper. Buy it from gmpartsdirect.com. You'll need the part number. I don't have it, but if you search in the ECUFlash forum, you should be able to find it.
Old Aug 25, 2010 | 08:23 AM
ssg_petty_210's Avatar
Go check out www.evodynamics.com
They have what you need. I am running it and I absolutely love it.
Old Sep 7, 2010 | 06:04 PM
advancEvo27's Avatar
im running it also, lovin it
Old Sep 7, 2010 | 08:04 PM
Methodical4u's Avatar
I'll likely be running one... I have the Grimmspeed, but one of the pins came loose from the connecter, I tried to fix it, but it still doesn't work. Something about the GS I just don't like for some reason... I have some really good 3 port maps, but I want to try the GM one out.
Old Sep 8, 2010 | 10:37 PM
GrimmSpeed's Avatar
We can get a new one sent out to you asap. Send us a PM with your info. I apologize for any inconvenience this has caused you.
Justin
Old Sep 9, 2010 | 12:20 AM
Justin
Well I guess you don't get much better customer service than that do you? I'm going to stay with them, and I would recommend them for ease of resolving problems.
19fred82
Jun 14, 2011 06:39 PM
SpoolinUp
Dec 1, 2009 04:24 PM
4xforce
Sep 5, 2009 02:40 AM
Kracka
Mar 5, 2009 07:59 AM
mrfred
Nov 7, 2008 03:25 PM
