Loud "clank" noise from rear end
Subscribe
Aug 25, 2010 | 01:51 PM
Sometimes when engaging the clutch, i can hear a "clank" noise coming from the rear end. It only happens once as soon as the clutch engages. No it has nothing to do with the exhaust. Could it be the differential?
Reply 0
Aug 25, 2010 | 02:21 PM
Might be you letting off the clutch too fast. My 8 used to do that until I learned to drive her properly.
Reply 0
Aug 25, 2010 | 02:24 PM
Might be time for some Beatrush rear diff bushings.
Reply 0
Aug 25, 2010 | 08:34 PM
Quote: Might be you letting off the clutch too fast. My 8 used to do that until I learned to drive her properly.
I can hear it when i let off slowly also.
Reply 0
Aug 25, 2010 | 08:37 PM
I'm pretty sure its our e-brake shoes sticking. If you don't use your e-brake, and park it in gear, see if that makes that noise not occur. Pretty sure that's why mine does it.
Reply 0
Aug 25, 2010 | 08:38 PM
Quote: I'm pretty sure its our e-brake shoes sticking. If you don't use your e-brake, and park it in gear, see if that makes that noise not occur. Pretty sure that's why mine does it.
the e-brake shoes suck IMO anyway. This isn't setup stock to do fast-and-furious type of drifting. Not mine anyway.
Reply 0
Aug 26, 2010 | 03:15 AM
yeah mine makes the same noise, and i figured it was the shoes sticking because it only happens right after the I release the ebrake
Reply 0
Sep 2, 2010 | 03:33 PM
thats what my guess would be...
Reply 0
Subscribe
