Rear o2 sensor plug... where the hell is it under the seat?
Old Sep 9, 2010 | 08:45 PM
Methodical4u's Avatar
I cannot seem to find it, anyone have any pics or anything of it?
Old Sep 9, 2010 | 09:16 PM
ZWingerRyRy's Avatar
Why are you looking for the rear ? I thought it was your front o2 that was acting up?
Old Sep 9, 2010 | 09:22 PM
yeah it is... I tried cleaning it, but it's still giving me minor idle issues and the SES light is still on... so I was going to look it over and possibly try Tephra's idea and swap them. It's either that or get that universal tomorrow, but I hear that anytime you cut and splice wires you loose signal... which isn't the first time i've heard that, don't know how true it is.
Old Sep 9, 2010 | 09:36 PM
Never bothered slicing o2 sensors. Cant determine is the wiring or the sensor is bad. So i just replace the whole unit. Rear o2 is under the passenger seat. The part numbers are different for a whole unit replacement. Yea the sensor might be the same but the connector might be different. I never bothered looking for the rear o2, youll have to take off the passenger seat i'd assume.
Old Sep 9, 2010 | 09:40 PM
densos number is the same.. I think they are different because the rear sensor's wire is something like 6' long.
I would replace the whole unit, BUT the unit is 272.00 vs 43.00? I'm not one to spend all that money, how do I know this one won't go out in no time?
After cleaning it the AFR was more stable so I think that getting some of the carbon off the sensor helped, and maybe it needed more time to sit. I don't know what to do.
Old Sep 9, 2010 | 09:44 PM
white8's Avatar
You dont have to take out the seat its under a moveable flap of carpet in the upper laft hand corner by the center console side. You might need get a flash light in there to see it better
Old Sep 9, 2010 | 09:46 PM
What gas you running? E85 or Race gas are likely to kill o2 sensors quicker.
Old Sep 9, 2010 | 09:47 PM
in this lame town? lol there's not a drop of e-85 anywhere. I'm running 93.
Old Sep 9, 2010 | 09:48 PM
have you confirmed this on the X or just on your VIII?
Well it took 15k for my o2 to go out. I dont mind paying 272 every 15k considering it took me 2 yrs to hit 15k on the X. Keeps my car running correctly. Pays to play?
Old Sep 9, 2010 | 09:54 PM
white8's Avatar
O this is for an x my bad cant help ya there.
oh yeah, definitely agree.... it's just right NOW I can't afford the 272.00, but if I can get it cheaper and if it works then i'm doing pretty good.
Old Sep 10, 2010 | 05:22 AM
Kracka's Avatar
I removed my rear sensor on my X a few weeks ago. Slide the passenger seat all the way back and reach your hand through the slit in the carpet, there are quite a few wires under there but just feel around for the one with a rubber grommet leading under the car then follow that one back to the plug. I did it just by feel, no flashlight or seat removal required.
Old Sep 10, 2010 | 10:17 AM
I'm just not sure the front is even long enough to reach the rear bung.
Old Sep 10, 2010 | 06:56 PM
Found a denso OE style... the sensor, wire, and plug for 61.00 + 8.50, so I went with it. I verified it with Denso as well that it was the correct one. Hopefully once I get that, there will be no more problems.
