Ultimate Racing vs. Rexpeed Downpipe
Old Sep 13, 2010 | 09:36 AM
twinturbogreg's Avatar
I know the rexpeed is alot cheaper and people say it might be more prone to cracking. From the outside they look alot alike. The biggest differance I notice is the flange that mates to the turbo. The Rex one has pretty much one hole and the UR has 2 openings.. one for the turbine wheel and the other for the wastegate. Now I don't think UR sends a gasket that seperates the 2 holes?? To me the Rex style seems easier and you can use the stock gasket. What's everyone think? Here are a couple pics
Old Sep 13, 2010 | 09:41 AM
Guru's Avatar
I used the UR one myself and was MORE than pleased with it. I had mine ceramic coated and worked flawlessly with my red for quite some time with 0 issues. I would recommend! The Rexspeed pipe I have no experience with. I've heard it is a decent piece.
Old Sep 14, 2010 | 02:06 AM
solipsism's Avatar
I had no problems installing the UR DP (take off that backwards-*** stud was another story). Everything that I needed was in the kit as well.
I also bought some heat wrap to cover it up with.
Old Sep 14, 2010 | 07:45 AM
journeymansteve's Avatar
I like the UR flex piping a lot. I'd not worry much about the opening on the UR being a performance decrease/impact; the AMS and ETS designs also have an assymetric style for the routing of the exhaust flows.
Old Sep 14, 2010 | 08:24 AM
ETS Michael's Avatar
You want to separate the waste gate gases from the turbine gases. This will prevent excess turbulence when the waste gate opens and closes. When the waste gate closes it acts as a suction.
Running a gasket is also highly recommend to prevent any leaking between the two. Also, do not run a down pipe with an external waste gate after the turbine flange. These type of units are prone to leak. If they leak before the external waste gate it will cause slow spool up and it won't be an audible leak due to it leaking into your exhaust stream. It's a hard one to detect.
Good Luck!
Michael
Old Sep 14, 2010 | 11:38 AM
Good Luck!
Michael
Thanks for adding your knowledgeable 2 cents Michael!
Of course any aftermarket is an improvement IMO over the crappy OEM one! Wow, what a POS that design is for airflow.
Old Sep 14, 2010 | 12:51 PM
Kracka's Avatar
MAP includes a divided gasket with theirs.
http://www.maperformance.com/map-sta...e-ss-evox.html
Old Sep 14, 2010 | 01:22 PM
Originally Posted by Kracka
MAP includes a divided gasket with theirs; I also assume ETS does.
Yup! We do.
Michael
Old Sep 20, 2010 | 09:04 AM
ChrisCarey's Avatar
Thanks for the referral sir! To the OP, we sell all of the aforementioned downpipes so certainly let me know which you decide to go with My only concern with the Rexpeed unit is the metallurgy as it is made overseas, I haven't heard any complaints in regards to fitment and certainly not pricing lol.
Old Feb 27, 2013 | 11:56 AM
Minox's Avatar
I would spend a little more and go with either MAP, ETS, or AMS
Old Mar 2, 2013 | 09:18 PM
ikt's Avatar
ikt
Rexpeed=Junk
Old Mar 3, 2013 | 08:05 AM
Illumin8's Avatar
Originally Posted by ikt
Rexpeed=Junk
Seen a bunch of threads with poor UR welds on exhaust components. Ets all the way, my preference. Can't go wrong with the big names like ETS, AMS, MAP.
Old Mar 3, 2013 | 10:11 AM
GsrJake's Avatar
I've bad my UR long downpipe for a few months. No problems
Old Mar 5, 2013 | 10:18 AM
ikt's Avatar
ikt
idk about UR, but I know ETS very quickly established themselves as a great company
TheMyth
Jan 25, 2018 06:23 PM
derekvr4
Jan 10, 2011 07:56 PM
aka.ralliart15
10
Mar 15, 2010 08:45 PM
vendetta714
Sep 22, 2009 01:29 PM
vendetta714
Aug 12, 2009 04:14 AM
