Need help with coolant lines on 35r turbo
Old Sep 25, 2010 | 01:27 AM
sideway180sx's Avatar
Im in the middle of installing the turbo and don't know which coolant lines goes where, i just need to know which line goes to the coolant pipe that come off from the water pump and the the one near the thermostat.
Old Sep 25, 2010 | 10:11 AM
spdracerut's Avatar
I would route it similar to stock; the water line next to the engine block should go to the hardline that runs along the engine block with that port being near the compressor housing. Route the line that's along the firewall around the compressor housing to the upper coolant line that use to attached to the OEM hardline that wrapped around the compressor housing.
Old Sep 25, 2010 | 10:21 AM
Does it matter which water line goes to?
Old Sep 25, 2010 | 10:40 AM
overboostin's Avatar
call ets to make sure!!!!!!!!!!!
Old Sep 25, 2010 | 10:57 AM
i dont think they are open on saturday
Old Sep 25, 2010 | 11:10 AM
aronjaskim's Avatar
It does not matter. Hook it up which ever way is the easiest and makes the most sense. I did it just like said in post #2
Old Sep 25, 2010 | 11:16 AM
Knowing that it does not matter which waterline goes to helps out big time, thanks
Old Sep 25, 2010 | 05:39 PM
rep tha 561's Avatar
nice looking set up by the way.
Old Jun 11, 2014 | 09:53 AM
kuronoko's Avatar
I wanna add an fitting to my 35r for my coolant lines but I'm stuck i don't know what kind of fittings or how much line i need. What did you use?
KJS
Nov 15, 2015 04:53 PM
rjfg
Jul 15, 2015 06:27 PM
Blitz
May 16, 2014 08:43 AM
LGrady31
Oct 3, 2009 04:26 PM
naudlee
Aug 15, 2009 12:10 PM
