Vibration when accelerating?
Old Mar 19, 2013 | 10:16 AM
  #61
Sunwalker12's Avatar
Has to be related to ride height...lowering the car changes the pinion angle on the prop shaft and thus throwing it out of tolerance...there is a threshold where the shaft has room to play but by lowering it past a certain degree throws it out of tolerance and places the shaft in a bind causing the vibrations some of you are experiencing. By continuing to drive with the prop shaft out of tolerance puts unneccesary wear on the support bearing and can affect how fast the pinion bearing wears (leading to failure of the carrier assembly and possibly wearing the housing of the diff). I come from the Mustang world and have had plenty of experience from support bearing failure/pinion failure/diff housing failure due to excessive lowering. The only way to resolve the issue is to raise the vehicle or to adjust the pinion angle to bring the prop shaft back within tolerance (on a mustang an adjustable upper control arm solves the issue)...surely there has to be a way to adjust the pinion angle on the IRS housing...
Old Oct 22, 2015 | 05:24 PM
  #62
Hallster's Avatar
Originally Posted by cdmassee
I had same problem...
Some vibration under power at higher speeds.
I installed Torque Solutions Driveshaft Carrier Bushings:
http://www.maperformance.com/torque-...l#.UUeZd9HSO9Y
took me literally fifteen minutes.
and then the vibration was gone.
Now and then if I really feel for it I can catch a tiny bit of vibration at certain rpms, But it Helped a lot.
I should have done it sooner.
It may help you guys? or it may be a improperly aligned clutch.
cdmassee,
When you wrote you had the same problem, I just want to confirm; you get a vibration under acceleration in 3 or 4th gear?
If so, I'm planning on getting these bushings. I have an '11 GSR w 21K miles; I have the 3rd/4th accel vibration issue as well. I got the car w 20K miles on it, so I'm not sure if this is an pre-existing or new issue.
Lowering springs? Yes. Tomei green.
As an aside: it's odd, this problem is not definitively solved yet - this thread just died down and looks like no new information.
TIY!
Hallster
Old Oct 26, 2015 | 09:24 AM
  #63
Hallster's Avatar
Anyone have additional information they can add to this thread?
TIY,
Hallster
Old Oct 26, 2015 | 12:18 PM
  #64
hoobastnk90's Avatar
Yea I have the same problem I just gave up trying to figure it out. It only does it with my aftermarket wheel setup so I assume its something to do with that at least for me ne ways.
Old Oct 26, 2015 | 01:36 PM
  #65
Hallster's Avatar
Thanks for the reply, hoobastnk90
My car does have aftermarket wheels/tires. Also lowered. Hmm... something to consider.
I ordered the bushing kit today. I should have those installed this week. I'll post up here w my findings after I get 'em isntalled.
Hallster
Old Oct 28, 2015 | 09:23 AM
  #66
yea a lot of people with after market wheels end up having an issue because the evo wheels are hubcentric and most after market wheels are lugcentric. And this small difference causes some wheel vibration I believe. They do sell hubcentric ring adaptors though that some people have had success with.
Old Dec 22, 2015 | 04:06 AM
  #67
dtmevox's Avatar
any updates with this ?
Old Dec 23, 2015 | 12:41 PM
  #68
Nope mine still does it lol. But when I swap back to my stock wheels for track days its all good. So for me im pretty sure its the lack of hubcentric rings
Old Jan 21, 2016 | 04:05 PM
  #69
dtmevox's Avatar
i raised my car up about a 3/4 of an inch ,(im on fortune auto coils) and it pretty much stopped ,, i think its the rear axles ?or cv joints .
Old Jan 21, 2016 | 04:47 PM
  #70
LetsGetThisDone's Avatar
No. CV, as in Constant Velocity, joints don't care what angle they're at. Unless your car has a lot of miles and one is worn out. And by a lot of miles, I mean a lot. Over 200k. CV's don't usually fail unless a boot cracks and they lose grease.
Old Jan 23, 2016 | 05:26 AM
  #71
dtmevox's Avatar
CONGRATS ! you know hove a cv works ...yay . so do i , but this is an axle bind issue , lower the car by a certain amount the axles become too short and they bind a bit , you just have to find the sweet spot to combat it .
Old Jul 20, 2016 | 05:13 AM
  #72
squid10r's Avatar
ISSUE FIXED, guys!
I finally figured out a way to fix this grunt or vibration on 3rd/4th under boost.
At first i changed the driveshaft carrier bushings from torque solutions. Didn't do anything. THen I got the diff bushings (urethane inserts). The issue is 100% fixed now. I also bought the metal bushing that goes into the rear of the differential but i couldn't figure out how to take the old one out. It turns out that only thing you need is the inserts.
Old Jul 20, 2016 | 03:18 PM
  #73
Hallster's Avatar
Thanks squid10r!
Could you post a link to the bushings you used? I found these, but this include the billet pieces as well:
http://www.torquesolution.com/product-p/ts-evx-003.htm
Thanks again!
Originally Posted by squid10r
ISSUE FIXED, guys!
Old Jul 20, 2016 | 04:12 PM
  #74
squid10r's Avatar
Originally Posted by Hallster
Thanks squid10r!
Thanks again!
I bought that exact kit. I only installed the urethane inserts. I wanted to get the aluminum billet piece in also but i couldn't figure out how to take the old one out.
Doing urethane inserts took the vibration away completely. I even checked it with my heavy 240lbs friend in the car hahaha
Be ready to spend some time getting those bushings pressed out. Mine were so seized that we has to use an air hammer to "fold" in the steel outer rim of the bushing inward to make a sort of a ledge to then press it with a socket. Otherwise, the steel part of that bushing is so thin that the socket was just wedging itself inside of the bushing and not pushing on the top of it. I hope that makes sense.
Old Jul 20, 2016 | 05:46 PM
  #75
squid10r's Avatar
Info on my set up:
stock struts with H&R springs.
