Evo X Dump pipe limit
Old Oct 30, 2010 | 02:29 PM
FQ4OO's Avatar
Hi All,
What is everyone's experience with stock dump pipes and when it starts to limit power?
Changing from a X MR stock turbo on pump (equiv to 93 octane) making 300whp (DD CF1.0) on ~25psi tapering to 20psi then no other changes except an FP Green 73HTA and the car made ~310whp on same boost. So obviously there is a restriction somewhere.
The airbox and filter was removed for a test dyno run and there was ~1hp gain, so it doesn't look to be a restriction.
The car has
3" TBE
High Flow Cat
Ralliart Panel Filter
Walbro intank pump
800cc injectors
3 port boost solenoid.
flash tune
Other cars on the same dyno with similar mods have made ~365whp the only difference being a dump pipe.
Therefore it seems obvious the dump is an issue.
Curious to hear other peoples experience.
Cheers
Old Oct 30, 2010 | 02:54 PM
H Jensen's Avatar
HFC is probably a restriction, and what TBE exhaust are you using?
Old Oct 30, 2010 | 02:56 PM
FQ4OO's Avatar
hfc?
the tbe is a TurboXS system.
Old Oct 30, 2010 | 02:57 PM
H Jensen's Avatar
high flow cat.
Old Oct 30, 2010 | 03:00 PM
FQ4OO's Avatar
Originally Posted by H Jensen
high flow cat.
i would agree it would be at ~360whp+, but its a 100cel cat, surely not restricting a fp green 73HTA from making more than 310whp?
JohnBradley
Evo X Dyno Results
May 1, 2016 08:10 AM
JohnBradley
Evo X Dyno Results
17
Jun 29, 2015 01:35 AM
tscompusa
May 23, 2014 01:36 PM
EvocentriK
Feb 18, 2012 06:34 AM
Pentaxis
Nov 10, 2007 04:59 PM
