service required light
Old Nov 13, 2010 | 11:10 PM
RREvoxGSR's Avatar
so i was driving earlier today and my service required light came on and the tarmac display went away, i shut off the car for a few minutes and it happened again. it has happened a few times now and i don't have time to take it to the dealership. anyone have any clue of what the problem could be?
Old Nov 14, 2010 | 08:16 PM
RREvoxGSR's Avatar
ttt
Old Nov 14, 2010 | 08:33 PM
twinturbogreg's Avatar
You probably just need an oil change.
Old Nov 15, 2010 | 11:38 PM
dragonetti's Avatar
Does it come on as you are driving or just when you start the car?
Old Nov 16, 2010 | 06:24 AM
RREvoxGSR's Avatar
A few minutes after I'm driving.
Old Nov 30, 2010 | 12:35 PM
Wrex1977's Avatar
you can set this to come on at certain miles or months for oil changes. if you have the owners manual how to reset it is there as well as setting it up to be a reminder. if you are really worried I would go to the dealer.
Old Nov 30, 2010 | 01:06 PM
ferocus's Avatar
does your car display a " *** Error" message just before "service required" ?
Old Nov 30, 2010 | 01:16 PM
ToddMcF2002's Avatar
If it is your service warning read the manual, it tells you how to reset it. I'm not using the dealer for service so I do that regularly.
Old Nov 30, 2010 | 02:04 PM
dek0026's Avatar
just reset it.
with the key out of the ignition or with the key in and turned to "off" position, scroll to the service reminder, then hold the info button down for 3 seconds until it beeps and blinks then push the info button again and it will clear.
Old Dec 1, 2010 | 11:35 AM
RREvoxGSR's Avatar
My tarmac display doesn't show when its on either
Old Feb 14, 2011 | 08:13 PM
RREvoxGSR's Avatar
bump, i'm starting to drive it again and i have absolutely no time to go to the dealership.
Old Feb 15, 2011 | 03:43 AM
RREvoxGSR's Avatar
Up, I had to drive the car to work this morning so I took the highway and when I went to stop the car died on me twice
