GSC S1 for Fp Green setup?
Old Dec 5, 2010 | 10:12 PM
Wht9er's Avatar
I've been reading through trying to find info on the GSC S1s. I do not want to upgrade my valvetrain so was curious how beneficial these cams would be on an fp green setup.
Old Dec 5, 2010 | 10:33 PM
glomb23's Avatar
I don't think you'll see enough results to outweigh the cost on the install honestly.
Old Dec 5, 2010 | 11:58 PM
Wht9er's Avatar
i was thinking that would probably be the case. i was hoping for maybe 25whp, but does anyone have first hand experience with these?
Old Feb 13, 2011 | 12:43 PM
brucksport's Avatar
i saw more than that on a std turbo with GSC S1,,with no loss in torque ,,,so im guessing they must be of some use with the Green...........the graph is somewhere on this board,,im gonna have to find it and link it
Old Feb 13, 2011 | 03:52 PM
scheides's Avatar
EvoM Moderator
If you're gonna do cams on an X, go big. Get some basic beehive springs for $250 and put them in w/ the head on the car. I wanted the S2's SO bad but due to no stock ended up with the Kelford 214-B's. I absolutely LOVE them, they improve spool/bottom-end so much its just amazing! These really really set off a bigger turbo on an X. Smaller cams or on the stock turbo I say meh--rock the stock cams. For as much work as it is to do cams on an X, go big.
Old Feb 14, 2011 | 02:07 PM
steinvb12's Avatar
Right, if you are going to get cams, you might as well go big. If you are out for a big turbo and 500+whp then get the S2's. If you have a milder turbo, then the Kelford's seem really good too.
I will probably rock the Kelford 214B's and a medium size turbo.
Old Feb 15, 2011 | 07:29 AM
jwwu's Avatar
Would you guys who say the same for MRs? i.e. more aggressive cams GSC S2 or Kelford Bs for MRs?
I can't find any dyno results
romogst
May 11, 2018 05:15 PM
5k6
E85 / Ethanol
Dec 20, 2016 05:13 PM
silverflyer
Nov 20, 2016 04:06 PM
jhoff007
14
Jun 9, 2008 07:35 PM
Kevin Knight
Sep 28, 2007 08:53 PM
