IndyEvo's 11 second X MR blown motor/build thread !!
Old Dec 3, 2010 | 06:25 AM
  #46
murlo26's Avatar
Originally Posted by ChanceR
Not sure how they could be considered isolated incidents when there are lots of e85 cars that are having major issues with it.
Minnesota has more E85 stations than anywhere in the country by a long shot...we have a **** load of E85 Evo's here and no one ever has this happen. There are several theories out there, but the one most tuners here suspect are just ****ty stations where people fill up.
Regardless, I am yet to see an X with this issue.
Old Dec 3, 2010 | 05:46 PM
  #47
ChanceR's Avatar
The car is in no way relevant to this happening. Altitude may have some dealing in it but there is no way you could ever say no car from Minnesota has this issue with e85
Old Dec 4, 2010 | 05:11 PM
  #48
WREvo's Avatar
Man thats a shame. I am sure that you will come back with one bad *** Evo
Old Dec 4, 2010 | 05:24 PM
  #49
Doug200T's Avatar
Damn best of wishes and let's see the mr monster rise again
Old Dec 5, 2010 | 07:37 AM
  #50
IndyEvo66's Avatar
Originally Posted by chunkymr
what kind of power was this making
never made it to a dyno, but it had to be around 450whp/400wtq
Question for you indy, did you happen to look at the tips of your injectors when you pulled them along with the intake runners? If so did you see anything out of the norm? Also how long was the car on e85 without running any pump gas through the system?
-Chance
my injectors where clean. have been running e85 for about a year (15k) never seen any problems. i swapped to e85 with less than 7k on my car.
Old Jan 10, 2011 | 12:25 PM
  #51
IndyEvo66's Avatar
bump...because guys are posting threads with like problems!
Old Jan 10, 2011 | 12:35 PM
  #52
murlo26's Avatar
What problem would that be? Too much power on the stock block syndrome?
Old Jan 10, 2011 | 05:20 PM
  #53
Hiboost's Avatar
Gets me re-thinking my strategy of making more power on my stock block setup. Maybe it's time to do a decent buildup of the engine after all.
Old Jan 10, 2011 | 06:28 PM
  #54
k20toEVO's Avatar
I wouldn't have just sent them in, I would have had them flow tested infront of me at a local shop. Whats to say they are not lying to save a huge headache?
Old Jan 10, 2011 | 07:15 PM
  #55
chkmgnt59's Avatar
For sure chris, weren't you looking to go bigger on your turbo as well?
Old Jan 10, 2011 | 07:28 PM
  #56
FLOW1's Avatar
Damn that really blows man...good luck on this next motor.
Old Jan 10, 2011 | 07:44 PM
  #57
willyan1989's Avatar
wow, I hope you are going to get your car back to the top!
MR ftw.
Old Jan 13, 2011 | 08:26 AM
  #58
IndyEvo66's Avatar
no. dw injectors failing.
i would save your self the trouble and just build it now. it's pretty much been proven these motors don't like to make torque down low.
i wish i had them tested myself too. you should see the return auth paper
the sent back with my refund check. the line where the test results are in has been whited out and blacked out with a marker and written over top of. it just says issue check per mike. lol
MR ftw.
my car is still on top. two holes in the motor or not. nobody has went faster. haha
Old Jan 13, 2011 | 08:39 AM
  #59
murlo26's Avatar
2 things.
1. I am happy you are on top for the MR's and not that weird *** Australian who uses cavemen equipment to measure his time.
2. So what did DW say about your injectors? You didn't call to question that? I am curious if they said there was actually a problem. Even if there was a problem they wouldn't be liable for anything other than their injector as that is the risk we take with modded motors. I am just curious if you had a legit failure. Not trying to go one way or the other, just want to see what happened with your motor as you were on the torque limit as far as a stock block goes. It is easy to blame one thing or another when a motor goes but to truly find out the problem is tough with this kind of devastation.
Old Jan 13, 2011 | 11:28 AM
  #60
onboost's Avatar
just a question, if the injectors were to fail i would think it would melt a ring land off a piston, not break a rod? as the pictures appear a rod has been through the side of the block.
I had an injector fail on my 2jz race motor and it melted the ring land off the piston and put it through my turbo.
