IndyEvo's 11 second X MR blown motor/build thread !!
2 things.
1. I am happy you are on top for the MR's and not that weird *** Australian who uses cavemen equipment to measure his time.
2. So what did DW say about your injectors? You didn't call to question that? I am curious if they said there was actually a problem. Even if there was a problem they wouldn't be liable for anything other than their injector as that is the risk we take with modded motors. I am just curious if you had a legit failure. Not trying to go one way or the other, just want to see what happened with your motor as you were on the torque limit as far as a stock block goes. It is easy to blame one thing or another when a motor goes but to truly find out the problem is tough with this kind of devastation.
akuma said the same thing you did. hard to pin point the cause of start of the failure.
You are in good hands
Enjoi926
May 31, 2017 06:47 PM
