Redline/Amsoil Transmission fluid
Old Dec 9, 2010 | 08:49 AM
boostawd16's Avatar
So i have always used redline or amsoild in my cars and has loved the way they shifted. I was wondering if these are good to use in my 08 gsr or if i should stick to the diaqueen factory fluid.
Old Dec 9, 2010 | 08:54 AM
derekste's Avatar
using amsoil is fine.
Old Dec 9, 2010 | 09:02 AM
iseedipp's Avatar
i agree, using AMSOIL is fine.
Old Dec 9, 2010 | 10:28 AM
Kracka's Avatar
Redline here; mix 2xMTL & 1xMT90 for the proper factory spec viscosity. Or you could try the new MT85 instead of mixing the cocktailX as we call it.
Old Dec 9, 2010 | 11:02 AM
heel_touge's Avatar
ive used both and the Redline cocktail works better IMO.
Smoother shifts, doesn't break down as quickly.
Old Dec 9, 2010 | 11:38 AM
derekste's Avatar
and your data is where?
also, I think anyone who claims smoother shifts suffers from the placebo effect, regardless of what they filled their gearbox with.
Old Dec 9, 2010 | 11:42 AM
Kracka's Avatar
He's stating his opinion which the Amsoil fanboys do plenty of so relax.
If you think it's all placebo affect then you're in a very small minority. I hated my stock transmission feel from the second I drove it off the dealers lot. I changed the fluid almost immediately and noticed a significant change in shifter feel. I can assure you, I wasn't so excited to spend $30 on fluid that I convinced myself it was better
Old Dec 9, 2010 | 03:12 PM
apagan01's Avatar
yes the spec of this oil MTG GL4 exceeds in all aspecs the diaqueen, and this data is documented. your tranny/pocket will thank you in the long run by using premium synthetics
Old Dec 9, 2010 | 06:37 PM
Guru's Avatar
I used the Redline MT-90 and worked like a charm!
Old Dec 9, 2010 | 07:08 PM
07outty's Avatar
redline mt85 at 2000 miles.
shifts much smoother.
Old Dec 15, 2010 | 09:21 AM
derekste's Avatar
1- a statement like "doesn't break down as quickly" implies knowledge of some sort of empirical quantitative data no matter how you cut it.
2- as far as shifting... I'll retract/clarify a bit: most people probably feel a difference, but it is likely more attributable to new vs. old fluid than it is brand vs. brand. in your case of perceived difference on a relatively fresh fill, don't forget that the initial 500 miles on a fresh transmission probably contaminates the oil more than the subsequent 50k.
if anyone honestly thinks they can blindly tell the difference in shift feel between a fresh fill of oe/amsoil/redline on a broken-in transmission, please let me know: I'll be happy to change your transmission oil with each respective fluid and buy the fluids themselves if you are able to identify all 3 correctly :P
Old Dec 15, 2010 | 10:00 PM
heel_touge's Avatar
put in amsoil a couple months before our first snow hit. engaged pretty smoothly. no complaints.
first big snow went out and romped for a couple days. low speed + high revs = high trans temps. i could tell the difference in smoothness of shifting as soon as the first evening.
I replaced the amsoil shortly there after. fluid was clean, no trans damage.
Put the redline cocktail in, tranny engaged a little more smoothly than the amsoil when i first put it in only a month prior. we had a bunch more snow days, beat on it much more with no change in smoothness or adverse effects. when it was time for a change, redline was clean with no trans damage either.
I have been flogging my honda on track for a few years now and can tell when its time for trans fluid change. I would say my scenario, in addition to my little bit of real world knowledge gives my comment some credibility. I was just giving the OP my personal experience to help aid in his decision. I changed fluids within merely a month each other; tactile memory was still fresh, no placebo effect here.
EDIT: i should mention this is in an 8. i didn't even notice i was in the X forums.
I'll also note that the amsoil would engage more easily on an ice cold gear box in the mornings. with the redline I have a bit harder time getting the gears engaged first thing in the morning in temps anywhere in the 30's.
Old Dec 16, 2010 | 09:33 AM
scarryy's Avatar
I changed the Diaqueen @ 15 and 30k miles. Didn't notice a difference between old and fresh Diaqueen. Switched to Amsoil around 40k, and did notice improvement. It is still a little notchy when cold, but MUCH better when warm, especially noticeable on the 2nd to 3rd shift at lower rpms. Have not tried redline, but I am convinced the fluid can make a difference in these trannies.
Old Dec 16, 2010 | 10:49 AM
RiG's Avatar
RiG
What Amsoil is recommend for the manual trans in these cars? On my GTO 6 speed man. it runs Amsoil Automatic trans fluid. I have run redline and B&G in my DSM and I like the redline cocktail, but Id like to try Amsoil in the Evo. Thanks
Mike
Old Dec 17, 2010 | 07:36 AM
derekste's Avatar
Mike
MTG https://www.amsoil.com/storefront/mtg.aspx
