Injector Sizes
Old Dec 26, 2010 | 10:00 AM
BaumBizzle's Avatar
Injector Sizes
Again, I fail at the search...I've found numerous sizes of injectors and curious as to what the HP figures would look like or approx how much HP can whatever size support? I saw the DW850cc stg 2 flash for the AP but what if I ran 650's? My goal is about 400whp....
Old Dec 26, 2010 | 10:11 AM
FedEvo8's Avatar
I would say go at least 1000cc minimum. That way if you ever want to use E85, you'll have enough fuel...
Old Dec 26, 2010 | 10:13 AM
THE8UH8's Avatar
I thought you need atleast 1200cc for E85??
Old Dec 26, 2010 | 10:16 AM
FedEvo8's Avatar
Depends on which turbo you are using...on a stock turbo, 1000cc will do.
Old Dec 26, 2010 | 10:18 AM
THE8UH8's Avatar
Learn something new everyday
Old Dec 26, 2010 | 04:54 PM
pikkagtr's Avatar
FIC 1100ccs for stock turbo /pump/e85
FIC 1680ccs for stock appearing turbos ie: BBX e85--These worked out great for me btw
Old Dec 26, 2010 | 05:04 PM
lowkey's Avatar
Registered User
Custom tune or OTS map? If OTS stay with what Cobb recommends unless you know how to set the injector scaling and duty cycle.
Old Dec 26, 2010 | 08:29 PM
BaumBizzle's Avatar
Currently using the OTS Cobb map but w/ tax returns I plan on getting a pro tune at GST. Wanting to get my ducks in a row with all my future parts installed so I'm not constantly needing a tune b/c I upgraded parts. Last parts to install are exhaust manifold, cams, and injectors prior to tune. As for upgrading the turbo I'll have to make another deployment to afford it...might have to put cams in that categorty too haha
Old Dec 26, 2010 | 08:31 PM
BaumBizzle's Avatar
If I got some of the ginormous injectors how bad would that affect my mpg seeing as how this is my daily driver? Kinda skeptical of stepping up to the 850's but you guys are droppin numbers like 1100 and 1600 etc and that seems HUGE!
Old Dec 27, 2010 | 09:18 AM
lowkey's Avatar
Registered User
You should consult with GST on what to buy.
Old Dec 27, 2010 | 09:42 AM
EvoX2NR's Avatar
I would go with 1000's just in case you decide to go E85. I am running right at the limit with ID1000's on a FP Red. The 850's are good for what you would like to do on pump though (if that is what you are going to run).
evoniners
May 20, 2016 04:56 PM
SmurfZilla
E85 / Ethanol
Mar 10, 2011 02:39 PM
ablan029
16
Jul 6, 2009 06:20 AM
Draven83
17
May 5, 2009 06:56 PM
pgmike
Lancer Aftermarket Forced Induction Tech
10
Apr 9, 2004 05:50 AM
