Car rpms stuck at 2k while in neutral! Help!!
Old Dec 31, 2010 | 01:47 PM
BoostedEvoVIII's Avatar
I have a Evo X with a ECU tune and a cone filter. Car has been running great for months. Today i went out and when i turn the car on, i got a CEL and the cars rpms are climbing to 2k while in neutral. I checked all the vacum lines and fpr line all is in check. Ive reset the battery and nothing! Any ideas what this could be? Thanks!
Old Dec 31, 2010 | 04:25 PM
waltezee's Avatar
What code is it throwing?
Old Dec 31, 2010 | 06:40 PM
Didn't get time to get it checked today. Im guessing it may be a vacuum issue. When I turn the ac on the rpms go back to normal and when it shuts off they go back to 2k. I've checked all the hoses and haven't found any disconnected. Any suggestions?
Old Dec 31, 2010 | 07:10 PM
dek0026's Avatar
Last edited by dek0026; Jan 1, 2011 at 06:53 AM. Reason: posting on nye after several beverages
Old Dec 31, 2010 | 07:48 PM
tephra's Avatar
P1235 probably..
go back to your tuner, if they dont know how to fix it - get a proper tuner...
Old Dec 31, 2010 | 07:54 PM
I'll get the code pulled tomorrow and let you guys know what it is..I had it tuned w/ ecu flash. Its been tuned for over 6 months
Old Dec 31, 2010 | 08:54 PM
tephra's Avatar
yeh, but its winter now - so you are probably hitting different loads/airflows...
Old Jan 2, 2011 | 01:37 PM
Ok I got them and I got Got codes PO131, PO137, PO102. I cleared them and car still idling at 1500-2k rpms in neutral
Old Jan 2, 2011 | 01:49 PM
rzs91's Avatar
call ur tuner and ask them? does sound like vacum issues
Old Jan 2, 2011 | 05:50 PM
tephra's Avatar
did the CEL go off after you cleared them?
Old Jan 2, 2011 | 06:35 PM
Robevo RS's Avatar
Maf sensor I assume. Swap it with an other one to check it. Takes 2 minutes.
Old Jan 2, 2011 | 06:53 PM
No. I'm assuming I may have a bad MAF. going to my tuner this week and see what the issue is
Old Jan 2, 2011 | 06:54 PM
tephra's Avatar
did you try re-reading the DTC's after you cleared them?
Old Jan 2, 2011 | 07:39 PM
No but I should have done that. I'll be going prob tuesday to my tuner to see what the issue is. I did notice that when the ac is on the rpms go back to normal and when it's off they go back up
Old Jan 2, 2011 | 08:25 PM
tephra's Avatar
is this an X or IX?
