any advantages to porting stock turbo?
not a fan of big laggy turbos. just curious if any advantages, thinking of cams, ets headers, fmic kit, intake, cbe, hks bov, injectors, upgraded fuel pump, and tune
Considering your mods list, why not just upgrade it? FP Green isn't exactly a big laggy turbo.
I swear the only reason you post on this forum is to see if anyone will respond...
There are no disadvantages to porting it other than the cost/benefit ratio may not be the best. With the stock turbine housing I always just do a simple gasket-match and smoothing port job, plus some ceramic coating to help retain the heat if you're feeling saucy. Plenty of vendors offer porting services if you're not comfortable doing it yourself or want something more extensive than the DIYer can do with a Dremel in the garage.
Here are a few examples I found for the 8/9, but the same can be done for the X:
http://www.paradigmperformance.net/p...o/hotside.html
http://www.maperformance.com/maperfo...bine-port.html
https://secure.buschurracing.com/cat...579969f39c3fc5
egis
18
Aug 15, 2013 08:07 PM
