possible clutch slip? need help
Old May 13, 2011 | 11:45 AM
EMSevo's Avatar
hey guys i have a 2010 gsr, just turned 25,000. i noticed that in 3rd and 4th gears while heavy accelerating or WOT on the highway, the car seems to hesitate then jump up rpm really fast? any advice?
Old May 13, 2011 | 12:34 PM
BalistiK_EvoIX's Avatar
Sounds like a slipping clutch.. does it not just jump RPM's and not go anywhere or what? Also, what kind of mods...might be worth it to see if the dealer can check it out and maybe call warranty on it... just my .02
Old May 13, 2011 | 03:59 PM
EMSevo's Avatar
it moves just fine, regular driving is fine. just WOT, if you are driving at around 3000 rpms and punch it, it seems delayed and then all of the sudden jumps up to high 4000s
Old May 13, 2011 | 04:00 PM
EMSevo's Avatar
mods are cobb ap stage 1 tune, cobb turbo inlet, agency power UICP, cobb sf intake
Old May 13, 2011 | 04:04 PM
Rnm's Avatar
Rnm
Definitely sounds like slipping clutch. Time to upgrade..
Old May 13, 2011 | 04:53 PM
EMSevo's Avatar
i figured so, so now whats the best clutch to get.... ha i know this could go on forever
Old May 13, 2011 | 05:48 PM
josh08gsr's Avatar
i had the same problem with my 08 gsr, yes your clutch is going.
Old May 13, 2011 | 05:50 PM
josh08gsr's Avatar
the best clutches to get would be a spec stage 3+ or a fx 400. either clutch is very good for pretty much anything you need.
Old May 13, 2011 | 05:52 PM
josh08gsr's Avatar
also you need to upgrade you cmc to a oem evo 9 w/a magnus adapter. other wise your stock one will give out. they are plastic junk, literally. use amsoil to change all of your fluids.
Old May 13, 2011 | 05:53 PM
josh08gsr's Avatar
i got the best deals from map performance on all of my parts.
MalibuJack
May 25, 2017 06:46 PM
MitsQueen
Aug 20, 2002 12:30 PM
