Oil Squirters Hitting Pistons
Old Jun 4, 2011 | 09:03 PM
bandit09's Avatar
So we're almost done putting the motor together, and just now installing the oil squirters, and they are barely hitting the pistons.
I have 90mm Wiseco HD pistons and Carrillo H-Beam rods.
I know some people used to delete these on the 4G63, and I think I remember reading ETS deleted their oil squirters on the Evo X.
I really have two options....I can try and bend and space it with washers to try and make sure the clearance is good everywhere (still kinda iffy because they vibrate and could do serious damage if it hit a moving part) or I can just remove them completely.
If I do delete them, I will have nothing delivering oil to my wrist pins, other than oil sloshing around.
Can I get some opinions on this please? What would you guys do, remove them or try and bend them? The car is gonna be mostly a DD / weekend warrior, but I also want to take it to the road course too and go all out.
Old Jun 5, 2011 | 05:31 AM
ugakirk's Avatar
From what I remember, on some the higher HP builds, they deleted the squirters. Personally, I would rather have them though..
Old Jun 5, 2011 | 01:36 PM
bandit09's Avatar
well I'm just concerned about the wrist pins and the piston heat if I ever were to do a track day or something.....Anyone else care to give their 2 cents?
Old Jun 5, 2011 | 02:06 PM
hotshot1's Avatar
I just recently built my motor and they didnot hit on assembly but did while running so I deleted them
Old Jun 5, 2011 | 02:08 PM
bandit09's Avatar
Were they super close during assembly? I think the rule of thumb is you want like 0.007" or so between the oil squirters and every other moving part because they vibrate a good deal and can move around a bit.
Old Jun 5, 2011 | 02:16 PM
Kracka's Avatar
Seems like a lot of builds delete them, but I'd personally want to keep them if at all possible.
Old Jun 5, 2011 | 02:20 PM
bandit09's Avatar
Yeah I keep going back and forth, I really don't know what to do.
Old Jun 6, 2011 | 09:56 PM
trippen1999's Avatar
what are the squirters made of?can the be bent slightly to get the clearance needed??
Old Aug 1, 2013 | 06:21 AM
2002EVOBOYTME's Avatar
Anyone tried to block them on 2.3L 650whp evo ? Will it have enough oil in the cylinder walls to not make scars ?
Old Aug 16, 2013 | 10:50 AM
nukerj's Avatar
They can be bent rather significantly - so carefully bend them out of the way and leave a good 1/4" clearance all around...
We had 2 break off and still ran the motor for 15k miles with no issues, on tear down everything looked fine except the bottoms of the 2 pistons.
Personally I would leave them in. Just use caution and common sense when bending them.
Old Aug 16, 2013 | 11:04 AM
nukerj's Avatar
Typically there is always enough oil mist in the engine case to lubricate everything. Hondas have been running 1000 whp motors for years with no squirters. But this only applies to forged components.
Old Aug 16, 2013 | 12:55 PM
murlo26's Avatar
I still have mine on my 2.2 motor.
I'd vote bend them. Honestly not sure what ERL did to mine to clearance it but it's not an issue in my build.
benIX
26
Feb 4, 2022 04:36 AM
1fast97gsx
Nov 4, 2016 01:10 PM
TrendSetter
Southeast Region
Jul 22, 2016 02:09 PM
jid2
30
Sep 3, 2014 10:07 AM
evoboy2006
20
Feb 16, 2014 05:55 PM
