FIC 2150cc question
Old Jul 11, 2011 | 10:45 PM
ImsoevoX's Avatar
FIC 2150cc question
I c maxed out my 1300cc injectors on e85. I am running a single dw pump and I am wondering would just changing the injectors solve my fuel issue? The pump is hard wired to the battery so it sees 14volts all the time. I am really trying to avoid the double pumper set up, but I want to make a little more power. I need more fuel to crank up the boost, currently set at 24psi.
Old Jul 12, 2011 | 07:15 AM
tephra's Avatar
2150 will be way to big on a 2.0
1680 is a good choice... BUT you will still need more pump... so I would be tempted to look into the more pump option first...
Old Jul 12, 2011 | 07:31 AM
chkmgnt59's Avatar
I ran into the same issue, maxing out a bosch 040 on pump, not even e85 w/ 1300cc injectors.
You didn't actually max your injectors, you maxed your pump. You need double pump, or an 044 inline, and suddenly you'll have more headroom on your 1300s.
Solve the fuel system first. My method is doing a brand new fuel system with a cell and all AN lines new rail etc. But you can probably get away with just adding an inline or a dbl pump and you'll have more headroom.
Beyond that, if you still want more (the black won't push all that much more, 600whp seems to be all it'll give) than 1680s is as big as you'll ever need. Though I'd be cautious with them, some ppl are having fueling issues w/ 1680s and we don't yet know the cause - it could be the injectors.
Jake
Old Jul 12, 2011 | 07:36 AM
murlo26's Avatar
I agree you maxed your pump not the injectors. My DW1300's let me run 38psi on the black with my double pumper with plenty of fuel left.
Old Jul 12, 2011 | 03:43 PM
ImsoevoX's Avatar
Yeah seems to be my problem I am running out of fuel. The BR double pumper is on back order. I am looking at this full blown kit but can't find any reviews. I need something quick fast and easy to install. Not to fond of the inline setup.
Old Jul 12, 2011 | 03:45 PM
ImsoevoX's Avatar
Murlo26 did you have a ported head?
Old Jul 12, 2011 | 03:48 PM
lonestarevo83's Avatar
What about the aeromotive 340lph pump?
http://youtu.be/Hz5Hw01_cwc
Old Jul 12, 2011 | 04:54 PM
murlo26's Avatar
Yes.
Oh, also, I wouldn't go with the full blown setup, it has problems from what I've seen.
Old Jul 12, 2011 | 06:46 PM
chkmgnt59's Avatar
aeromotive and dw pumps are the same pump. If you don't want to do a DP setup, or can't wait for backorder, you can either
1) add an inline 044
2) get a surge tank setup from MDR and run an 044
3) FUEL CELL!!! with 044s
Option 3 is only for the crazies.
I'm installing my fuel cell right now :-)
Old Jul 12, 2011 | 06:47 PM
mitsael's Avatar
Hey guys i had one of those Dw300 pump too i am running the FP black on my set up after the block build. I also have a MAP inline fuel pump should i install that as well instead that getting a double pump ?????
Old Jul 12, 2011 | 06:58 PM
EvoX2NR's Avatar
there is a double pumper in the FS section
Old Jul 12, 2011 | 10:13 PM
ImsoevoX's Avatar
OMG good catch thanks!!! I pm'ed the guy he's local hopefully I can take it off his hands!!
Old Jul 12, 2011 | 10:15 PM
ImsoevoX's Avatar
Thanks for the input guys, I will keep you updated. Hoping to have this fixed by next week fingers crossed!!!
Old Jul 15, 2011 | 05:57 PM
bandit09's Avatar
I'm going to be giving the 2150's a try, after having issues with the 1680's. I also have the full blown hanger, but haven't had it for long and haven't experienced any issues with it. Murlo, you said you saw it has issues? Could you please elaborate on that a bit?
Old Jul 16, 2011 | 04:55 PM
murlo26's Avatar
Lomker had the full blown hangar and he could never get it to work but who knows if it was the hangar or something else.
