Car makes 11 psi at 100% wgdc
Old Jul 28, 2011 | 03:57 PM
JDMCT9MR's Avatar
Originally Posted by cir-reed
I bought it used. I purchased it from a dealer in Florida and had it shipped up to Chicago. So taking it back to where I got it is not in the cards. I already stopped by the dealer in Schaumburg to ask a couple questions and they weren't too pleasant. I ordered an EBCS to see if the BCS is the issue.
Originally Posted by razorlab
I'm not sure if my question was answered before, did you buy this new or used?
If you bought it used, make sure you have the wastegate actuator side pill in the hose. If you do not have this pill the car will run wastegate pressure.
^ This is a great suggestion. I had to change out that hose on my car since the old one was destroyed. I forgot to move the pill over and the car was only boosting 11 PSI. Once I moved the pill over to the new hose it ran like its supposed to.
Old Jul 28, 2011 | 04:11 PM
RazorLab's Avatar
Ok I bet there is no pill in the WGA Hose. Or the OEM hoses aren't even on there. It's a pretty common thing on second hand Evos.
Old Jul 28, 2011 | 04:54 PM
cir-reed's Avatar
I found this thread with a nice diagram of the solenoid hoses and color coding:
https://www.evolutionm.net/forums/ev...oid-hoses.html
I just went out and looked everything over and they appear to be all connected to the right places. So I hope the leak test shows the way on this one.
Old Jul 28, 2011 | 04:57 PM
cir-reed's Avatar
I just saw this after I typed my post. If I take that hose off is it easy to see the pill in the hose? It's the hose that goes from the waste gate actuator to the plastic T fitting?
Old Jul 28, 2011 | 05:08 PM
RazorLab's Avatar
You should be able to feel it in the hose.
This should help:
Old Jul 28, 2011 | 05:56 PM
cir-reed's Avatar
Razorlab, that picture was exactly what I needed! I flip flopped the lines between the actuator and the outlet pipe and the car is a whole different animal now!
Thanks guys for all the input. I am glad it turned out to be something simple. I am now seeing 25 psi peak and seems to hold 17 or 18 to redline. I will log tomorrow and see exactly what it's doing.
Thanks again for all the help guys. Hopefully this thread helps the next person this happens to.
Old Jul 28, 2011 | 09:52 PM
RazorLab's Avatar
Glad I was able to help!
Old Jul 28, 2011 | 11:17 PM
tephra's Avatar
that pic even helps me
nice work B!
Old Jul 30, 2011 | 01:32 AM
JDMCT9MR's Avatar
Glad you figured it out!
black E
Evo X Dyno Results
75
Feb 21, 2016 01:28 AM
3000GT-GTO
Cobb AccessPORT
34
Aug 17, 2013 02:52 PM
sharkm87
Apr 7, 2011 03:45 AM
CornFedEvo
Dec 4, 2009 09:43 PM
R/TErnie
Oct 29, 2008 02:54 PM
