Odd Issue With Acceleration
Old Aug 9, 2011 | 05:17 PM
bobby0283's Avatar
So I've noticed a weird issue in the last week or so. Doesn't matter what gear I'm in, when I am at or near WOT I notice my RPMs will kind of shoot up but the car doesn't feel like it's pulling like it should. They'll come back down and then it will accelerate almost as normal, but still seems off. I've got 39,xxx on the stock clutch, I'm thinking it might be starting to slip? Any other telltale signs of slippage? I had the stocker on my last car until I traded it so I never felt a clutch at the end of it's life.
Old Aug 9, 2011 | 05:33 PM
binky's Avatar
To test if its the clutch:
Put the car in first gear to get the car moving slowly, shift to third gear and give it gas. If the clutch is worn the RPM's will go up then back down quickly and when the RPM's have come back down the car will begin to move forward.
What this does is it puts a load on the clutch. If the clutch can't hold the load, the RPM's go up until the clutch can catch up and then the RPM's will go down and the car will move.
FWIW, from how you describe it, it sounds like the clutch is shot.
Good luck.
-Bink
Old Aug 10, 2011 | 06:57 AM
01CBR929's Avatar
Bye bye clutch! Sounds like it's slipping based on your description... hence why the engine increases in rpms yet the car doesnt accelerate with the engine at the rate it should.
Old Aug 10, 2011 | 09:25 AM
Mad_SB's Avatar
clutch is slipping
Old Aug 10, 2011 | 07:46 PM
bobby0283's Avatar
Kinda what I figured. How much torque is the stocker rated to? I have an extended warranty that covers it, should I even go the OEM route or go with something like a Spec Stage 2+?
Old Aug 10, 2011 | 11:25 PM
anEVOx's Avatar
Warranty won't cover your clutch since it's a wear item. Only time it will cover your clutch is if there is a component failure such as a pressure plate, clutch fork, slave cylinder, etc.
I wouldn't go back to OEM since you're modded. Not sure about the Spec.
Old Aug 12, 2011 | 11:32 AM
bobby0283's Avatar
Any suggestions on a good clutch/flywheel package that isn't going to break the bank and is rated up to about 450 ft/lbs?
recur
Mitsubishi TC-SST Discussion
34
Jan 3, 2021 09:42 PM
tcdrvr2
Dec 4, 2012 07:59 PM
sirchumpalot
27
Nov 28, 2012 12:07 PM
supersiyx
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 25, 2012 05:03 AM
dyamanoha
Dec 22, 2011 02:09 PM
