Properly "Adjusting" Tial QR
Old Sep 28, 2011 | 12:09 PM
sobo's Avatar
Hey all,
I have a Tial QR on my stock turbo X. I get tons of compressor flutter and on the highway the car is very jerky. On Decel my car hits 22-24 in/hg and at warm idle it's at 20 in/hg. I run 30psi, daily. At wot, things are fine. But anything below that I get quite a bit of flutter.
I have a "Pink" or -11PSI spring in it.
What spring should I choose (Or do you run) that could possibly alleviate these issues?
-Alex
Old Sep 28, 2011 | 04:58 PM
jamevo8's Avatar
Years ago AMS did something with one of the mut scan tools to fix this problem for me if I remember correctly?
Old Sep 28, 2011 | 05:16 PM
HornstarBU's Avatar
Tial says
-18 and -21 in/Hg Un-painted -11 Psi (-22 in/Hg )
So you have the right spring...what's your idle set to, stock rpm? Also, there isn't much adjusting with the tial, just switching springs out....so you might check to make sure the vacuum port isn't kinked, or make sure there isn't a crack in it or something.
Old Sep 28, 2011 | 07:37 PM
Clipse3GT's Avatar
Softer psi spring.
Old Sep 28, 2011 | 08:22 PM
itzwolf's Avatar
Originally Posted by Clipse3GT
Softer psi spring.
Ditto, get the -8 psi spring.
You have pink, that's -11, unpainted is -10, I'd personally go with the white spring, ie -8 (-16 in/Hg )
Chart from Tial:
Engine Vacuum Reading / Color Use Spring
Between:
- 22 and -23 in/Hg -12 Psi (-24 in/Hg )
- 20 and -21 in/Hg Pink -11 Psi (-22 in/Hg )
- 16 and -19 in/Hg Un-painted -10 Psi (-20 in/Hg )
- 12 and -15 in/Hg White -8 Psi (-16 in/Hg )
- 8 and -11 in/Hg Black -6 Psi (-12 in/Hg )
HornstarBU's Avatar
Softer psi spring.
Then you leak at idle...which is probably okay since it's recirc. I'd say it's worth a shot if your vacuum source is known to be good and of a proper diameter and not collapsed.
Old Sep 28, 2011 | 11:28 PM
Hiboost's Avatar
I also had horrible flutter at part throttle 15-20 psi where the car wanted to rocket past to 25+ psi. Made tracking the car on a road course challenging and I had to adobt a more on/off pedal approach and kiss finesse goodbye... Swapping from an 11 psi spring to 8 psi helped but it was still there. Reducing my MIVEC agressiveness at 180+ load helped abit as well. Probably the biggest issue was the GTX30 turbo has a rather large compressor flow capacity compared to it's exhaust side so once you hit that 3500+ range it really wants to just go full boost.
On paper the Tial QR looks perfect but I had poor luck with it. Might be fine for WOT driving at a drag strip but daily driving and road course driving it was barely passable.
pog0
89
Dec 1, 2018 08:13 AM
Bmurray
May 24, 2017 02:23 PM
lghtngyello03
Feb 6, 2017 11:00 AM
escape1221
Nov 18, 2012 12:06 AM
Wirk
Oct 4, 2012 04:31 PM
