Megan DP rubbing transfer case
Old Oct 15, 2011 | 07:01 PM
Jookies's Avatar
Hey guys, just put in my Megan DP and it seems it slightly touches a very odd part sticking out of the transfer case and makes a soft rattle... Does anyone else have this problem? Should i be worried about this either damaging the transfer case or the downpipe?
Old Oct 15, 2011 | 09:58 PM
Jookies's Avatar
Would wrapping the spot that is touching the T-case in heat wrap alleviate the problem and the danger for damage? Or should i just remove it, put the stock DP back on and just forget this ever happened haha. ( a little clarification, the part that the pipe is touching is not the main part of the t-case, but rather a small part that is sticking out into the path of the downpipe.) I can live with a small rattle, but i can't live with replacing the t-case in 20,000 miles.
Old Oct 15, 2011 | 10:20 PM
fasolxpl's Avatar
i just started to experience same problem with the invidia downpipe hitting against the oil pan
Old Oct 15, 2011 | 10:25 PM
Jookies's Avatar
I didn't think it was a big issue until I saw these people who ended up with a broken t-case from it ( or in your case an oil pan haha) The guy at my shop told me it was gonna rattle, and I was like " w/e rattle is fine" lol
Old Oct 18, 2011 | 02:18 PM
phishy's Avatar
I had the rattle on my 8 with Invidia downpipe. I think wrapping it with heat wrap would suffice and prevent from extensive damage but that's just me thinking logically, who really knows.
Old Nov 30, 2011 | 07:27 PM
Jookies's Avatar
So it seems the downpipe has melted a very small groove into the piece sticking out of the transfer case ( melted or shaved off, idk haha) Should I be worried about this doing internal damage to the T-case? Or am i fine to just leave it alone?
Old Mar 29, 2013 | 10:18 PM
evoxboost's Avatar
I just installed megan DP yesterday and i have the same exact problem! im ok with the rattle but im not sure if its gonna damage the transfercase. i thought about wrapping it with heat wrap but haven't done it yet. Im not sure what to do. Do you still have the megan DP in??
Old Mar 30, 2013 | 04:25 PM
Jookies's Avatar
I do, and it actually did start to melt the casing for the TC. I would NOT suggest heatwrapping it either, as the rough surface on the heatwrap might wear away at the casing as well. What I ended up doing is marking where it was rubbing, and then hammering a dent at that spot so it doesn't rub. A little crude, but it got the job done.
Old Mar 30, 2013 | 04:46 PM
evoxboost's Avatar
alright, i was thinking of heat wrapping it anyway. so ill try denting it and wrapping it. how do you like the megan test pipe? i was gonna order it but they dont have it in stock at the moment.
nikush
Jan 9, 2015 03:02 PM
evo unknown
Dec 23, 2009 03:27 PM
JakeTheVIII
For Sale - Part Outs
22
Aug 9, 2009 03:01 PM
MaxR
Jul 14, 2007 11:18 PM
VIIImylunch
Jan 29, 2006 02:49 PM
