E-Spec "E-Stage 1" To be released!!
Old Nov 9, 2011 | 11:20 PM
  #31
slonez's Avatar
Originally Posted by E-Spec@Tach Motor Works
Intake is proper now!
We peaked 450hp@6100rpm where I let off--- I want to upgrade this kit with a 44mm wastegate vs the 38mm for better boost control. Saw boost climbing past 5500rpm.
Pics up on my next post.
Can it fit RHD models?
Old Nov 10, 2011 | 06:23 AM
  #32
tonyboy's Avatar
+1 for updates..show us that graph! i wonder how the turbo does on top with that housing. it is looking great indeed!
Old Nov 10, 2011 | 06:25 AM
  #33
Revo15's Avatar
Thats crazy awesome!!
Old Nov 10, 2011 | 07:42 AM
  #34
jyamona's Avatar
any idea which turbine housing it is? I couldn't really spot an adapter between the stock manifold and the turbo
anyway, yea we need an update! lol, it doesn't take 3 days to swap EWG's =P
Old Nov 10, 2011 | 01:54 PM
  #35
Slow98teg's Avatar
Hard to tell. Im about to pull my manifold off, borrow and friends T3 turbo and figure it out haha.
Old Nov 14, 2011 | 08:22 AM
  #36
jyamona's Avatar
what's going on w/ this???
Old Nov 20, 2011 | 11:15 AM
  #37
E-Spec@Tach Motor Works's Avatar
Updatse,,,
Success!!
Tach signal dropped on this sheet-- tq was not measured properly..
Fast spool-up and great power upstairs with ALL STOCK parts...
The larger precision 44mm gate and modified dp gave us the boost control we wanted..
20psi by 4400rpm.. On a JOURNAL BEARING 6262.
All in all this project outperformed my expectations.
Old Nov 20, 2011 | 11:58 AM
  #38
robnval's Avatar
When is this going to be available? Patiently waiting!
Old Nov 21, 2011 | 11:19 AM
  #39
jyamona's Avatar
awesome results! what did boost climb to in that graph? it looks like almost 30psi? a few other things...
1. can you get a chart up w/ the torque curve?
2. any plans to add the normal bolt-ons and re-dyno this?
3. are you using this turbine housing? (on the left, obviously)
4. if so, how does it bolt to the manifold?
thanks! and again, nice work.
Old Nov 21, 2011 | 08:29 PM
  #40
slonez's Avatar
Any plans to test the 5857?
Old Nov 21, 2011 | 08:43 PM
  #41
GdotRegEvo9's Avatar
nice !
Old Nov 21, 2011 | 10:19 PM
  #42
WarmMilk's Avatar
what he said
good to know I'm not the only one that likes spool...
Old Nov 23, 2011 | 10:22 AM
  #43
Jonnyblaze81's Avatar
I'm the owner of the car and just wanted to give everyone a feedback of the setup. I already put well over 400 miles on it and the car is still running strong. Below 4400 rpm the car is very easy to get around but once you want to play and get on it, it's a complete beast! Once the 6262 spools up you barely have time to catch the shift because it goes thru the RPM's so quick! The car feels awesome going thru the gears all the way up to redline. I personally can't wait to do the necessary upgrades so that we can really push the turbo. After all the motor/tranny is completely stock. In the short future I will be upgrading the IC, cams, pistons/rods, clutch & diff pins and also the final drive on the tranny to make a killer setup for the drag strip! Congrats to Erkel and the guys over at Tach motor for making an affordable killer kit!!!!
Old Nov 26, 2011 | 05:34 PM
  #44
louiesevox's Avatar
Any update as per when this will available? And if theres any talks of a group buy?
Old Dec 1, 2011 | 07:23 AM
  #45
jyamona's Avatar
soo what's the status? any answer's to my last post?
