Help! In middle of changing rear diff fluids - which drain plug is magnetic?
Old Nov 5, 2011 | 01:00 PM
LaXGSR's Avatar
Quick Q:
On the rear diff, there are two drain plugs. One is magnetic. Does that go on the part where the ATF SP3 is (torque transfer mechanism), or where the LSD gear oil is (differential mechanism)? I may have gotten the two mixed up.
Thanks!
Old Nov 5, 2011 | 02:12 PM
EvoX2NR's Avatar
the one that has a groove on the tip of it is for the LSD gear oil. I am pretty sure they are both magnetic though
Old Nov 5, 2011 | 05:45 PM
LaXGSR's Avatar
You're right, both are magnetic. The longer magnetic one goes to the ATF SP3. The shorter one with just a magnet embedded on the end of it goes to the LSD gear oil.
Old Nov 5, 2011 | 11:24 PM
scheides's Avatar
EvoM Moderator
I think think the magnetic one is the one that the gear oil goes in.
Thoe99
Apr 8, 2012 07:44 PM
osunick
52
May 25, 2011 10:20 PM
mooserov
Mar 7, 2010 10:33 PM
osunick
Apr 12, 2004 08:05 PM
shawnhayes
23
Nov 23, 2003 06:00 PM
