Is the X's clutch pedal adjustable?
Old Nov 21, 2011 | 04:27 PM
STi2EvoX's Avatar
I was just looking at the pedal assembly in my X, and the actuator rod is plastic (mitsu is so cheap these days), and there is no adjustable rod and lock nut that I can see. Am I missing something? What happens when you install an aftermarket clutch and need to adjust the engagement point... I guess you're just screwed?
Old Nov 21, 2011 | 05:52 PM
acdavis25's Avatar
You could get the magnus cmc conversion. It uses the cmc for the evo IX which is adjustable.
Old Nov 21, 2011 | 06:40 PM
STi2EvoX's Avatar
^Too many reported failures with the magnus, and I'll be damned if I'm going to pay nearly what a clutch costs for the ssp.
On a side note, I'd be willing to bet that the stock CMC not being adjustable has something to do with the X's terrible shift feel. If the clutch isn't fully disengaging between shifts, it causes synchros to grind and crunch, which is exactly what happens in the X constantly. I'd be curious to see if anyone who has installed an aftermarket CMC was able to rid their X of this problem...
Old Nov 21, 2011 | 07:19 PM
kyoo's Avatar
u back!
Old Nov 21, 2011 | 07:21 PM
STi2EvoX's Avatar
I back!
Old Nov 21, 2011 | 10:24 PM
WarmMilk's Avatar
the magnus only fail when use with reproduction master cylinder, a genuine mitsu master cylinder works well. I got mine installed at 2k along with a spec stage 2+ clutch, I'm at over 11k (almost 12 I think) now, 2 track days, one autocross, a bunch of launches on a deserted back road figuring out the best way to launch an AWD car, still going strong.
Old Nov 22, 2011 | 08:03 AM
jyamona's Avatar
yep, this.
Uscbryan
Jun 7, 2014 08:46 PM
Svendiesel
24
Jul 30, 2013 09:23 AM
Frew
May 20, 2012 04:44 PM
Mattkinn2004
Lancer Tranny/Drivetrain Tech
Mar 21, 2011 03:49 PM
bryan0
Jan 9, 2010 09:27 AM
