odd idle surge issue
Old Nov 26, 2011 | 10:45 AM
91GSX's Avatar
Ever since I got a clutch installed I have been having this odd surge issue.
If I am cruising in neutral, the idle surges 1000-1500-1000-15000 over & over again. When I come to a complete stop, the idle stabilizes & there are no problems at all. It only happens while i am moving in N. It doesn't matter if I push the clutch pedal in or not while I am moving.
Tune did not change & parts did not change (other than the clutch). Doesn't matter what temp it is outside & there are no boost leaks. (recently blt'ed)
Clutch is a Exedy twin HD...
Figured that I would throw this out there to see if anyone has any ideas.
Old Nov 26, 2011 | 02:21 PM
Spazpilot's Avatar
could be that the clutch is not totally disengaging all the way. I know that on my 11 when its cold and I"m backing up the second I let go it jumps to 1500 and then comes back down. This is on a stock clutch.
Old Nov 26, 2011 | 04:51 PM
91GSX's Avatar
yeah i suppose it's possible. It idles fine when I am stopped. It really doesn't bother me too much. I just found it quite odd. I noticed that when I was on the stock clutch it would do the same thing sometimes. With the exedy twin in there it does it all of the time. Wonder if any other exedy twin owners have this problem.
Old Nov 28, 2011 | 12:20 PM
jyamona's Avatar
do you have the magnus cmc kit? if so you can try adjusting the pedal...
Old Nov 28, 2011 | 03:10 PM
91GSX's Avatar
I do have the magnus kit. I could definitely give that a try. Thanks for the suggestion.
Old Nov 30, 2011 | 08:40 PM
harrymark's Avatar
Let the cleaner soak awhile, repeat as needed, then reinstall the IAC valve, start the engine and run it at 1,500 to 2,000 rpm as before until no white smoke is seen in the exahust.
CharliEvo8
Jan 5, 2025 10:14 AM
okevolutionVIII
Jun 17, 2017 06:21 PM
xMCxMRx
12
Feb 24, 2017 03:51 AM
randomevo
Dec 18, 2016 11:11 AM
blue4uevo8
Oct 3, 2011 11:28 AM
