coolant leaking from turbo hotside
so I noticed a burning coolant smell. I looked unter the hood near the turbo hotside and noticed white what appears to be dried coolant residue. I've been working all week so I haven't had time to do a leakdown test or compression test but based on the symptoms I'm not showing any signs of a bad HG. Its a garrett 3076r with a .63ar hotside and it seems coolant is leaking from where the 02 housing meets the hotside. I've searched and searched to see if a coolant lines/seals internally could leak into the hot side but wasn't able to find good info on this. Just through I would throw this to you all before I try and diognose on saturday. Anyone ever heard of this, and trust me I've thought and re thought about a bad HG but it was already replaced machined and arp studs installed and it's not showing symptoms of it so I really think it's within the turbo. Any input on this would be great.
doesn't appear to be leaking from the lines them selves exterior of the turbo either.
thanks
thanks
thanks
thanks
It is impossible for there to be an internal coolant leak in the turbo. So it's either coming from where the coolant lines connect to the turbo, or the coolant lines themselves somewhere.
But like I mentioned, a buddy of mine had the stock hard line crack.
Well you could have 99 people responding with "nope, never heard of this" if it makes you feel better!
If it's happening on normal drive cycles, maybe pop the hood and check to see if you can catch it in the act. Likely it's oozing out as the car cools and initially it's just a mist due to the heat. Probably once the engine starts to cool off but the cooling system is still pressurized it is starting to show a wet leak of coolant from the source of the problem.
update on this since it's been so long. It wasn't the turbo, it was leaking out of the dp because coolant was leaking from the block into the combustion chamber during cool down when the car would sit so when I started it up, it would burn/leak the little bit that was in the chamber. My solution was I pulled the whole motor and built it
