Which is recommended BOV?
Old Feb 19, 2012 | 05:16 PM
rrkpitt15's Avatar
Usually when you get flutter on the stock DV, you need to look at the tune to get rid of the flutter. Try adjusting the boost control maps and/or mivec maps.
Old Feb 19, 2012 | 05:24 PM
rrkpitt15's Avatar
Originally Posted by crimson red
Hi,
Thank you for the info. Ummm, I've been having probably same trouble with stock BOV since about my car became 3yo.
I also have to get same softer spring for Synchronic DV or almost every other BOVs.
Which spring rate do you use?
IDK what spring i have. I just contacted Aby @ Milspec because the tech guys at Synapse could not figure out why i was still getting flutter. They recommended me to Milspec. So Aby just sent me a spring to see if it would help and it did.
Old Feb 20, 2012 | 05:56 AM
crimson red's Avatar
oh I see. Thanks!
Old Feb 20, 2012 | 06:05 AM
SavageGSR's Avatar
what about the Cobb XLE BPV spring rate, any one know what should be in these, or are they fixable with in the tune?
Old Feb 20, 2012 | 07:01 AM
mirkendargen
Certainly. I can fit the BOV with AMS intake luckily.
ChopShop
okay, Thank you everyone, I'll try to choice my BOV from what your recommends.
Old Mar 8, 2012 | 10:33 PM
Inprogress's Avatar
How do the perrin valves hold up?
Old Mar 9, 2012 | 04:13 AM
ithveno339jfkj4kjekjqqqq's Avatar
what do people think of:
turbosmart dual port VS. cobb XLE?
Old Mar 9, 2012 | 06:06 AM
jyamona's Avatar
Hollywood has been running the Perrin valve forever. He seems to really like it. Maybe he will chime in.
Old Mar 9, 2012 | 06:33 AM
Showsol2211's Avatar
I used to have the turbosmart and it sounded awesome, but I had too many issues with flutter/bucking after getting tuned. Now I have the synapse.
Old Mar 9, 2012 | 01:35 PM
Mr. Move's Avatar
Tial or GTFO
Old Mar 9, 2012 | 01:53 PM
did you experiment using different springs in the turbosmart at all?
Old Mar 9, 2012 | 06:09 PM
RB185AFM's Avatar
Originally Posted by mirkendargen
There can be fitment problems with the big Synapse BOV depending on the style of your intake and return pipe. It doesn't fit with the ETS intake for example.
I run the Synapse Bov on my 4" ETS intake. No issues.
Old Mar 11, 2012 | 10:26 PM
Panda_stunter's Avatar
Originally Posted by ChopShop
I was running HKS for about two years with no problem. Just recently switched to the COBB. I would recommend both.
How is the Cobb xle treating you? R u running it 50/50 or full recirc? Hows the noise level?
I'm looking to get a Cobb but I haven't read many reviews with it being used on an X
Old Mar 11, 2012 | 11:53 PM
Martinezusn's Avatar
been running my perrin recirc bov on my x for about 2 years and no problems and best of all its adjustable and looks good and sounds good not that ricer-ish sound
Old Mar 14, 2012 | 04:06 AM
blacksheepevox's Avatar
strongly recommend synapse motorsports synchronic bov its fantastic
