AMS Downpipe, worth it?
Old Apr 7, 2012 | 07:48 AM
RAY101381's Avatar
so after doing a lot of reading, i've come to the conclusion a downpipe isn't gonna make that much power, coming from an sti this is complete blasphemy. my question is what if i were to get the o2 housing, i.e. AMS widemouth downpipe. In the end i don't plan on upgrading the turbo, injectors or intercooler, i want a simple RELIABLE stage 2. so far here's what i have in the garage.
Perrin Catback
Cobb HFC
AEM intake
my tuner recommended the pierburg boost solenoid. so after a tune is the AMS downpipe worth the $500? how much WHP/WTQ would i see and are there any boost creep issues?
Old Apr 7, 2012 | 06:05 PM
armysoldier1073's Avatar
Not a lot of increase, but helps spool a bit. It is noticeable.
Old Apr 7, 2012 | 06:10 PM
injentech42's Avatar
Interesting, for me my downpipe was one of my best noticeable mods I've done at first. Opened the car up
Old Apr 7, 2012 | 07:09 PM
2003evo8's Avatar
ams dp is a nice part would buy if u are not wanting to add a aftermarket turbo kit because most come with a down pipe
Old Apr 9, 2012 | 07:20 AM
steinvb12's Avatar
From a pure horsepower prespective, you are right, the downpipe will not get you much more horsepower, if any. The stock turbo does not flow enough to make a difference in hp #.
However, that's not to say there isn't some difference in response. You just have to determine if it's worth the cost to you. If you are not going to chance the stock turbo, it probably isn't.
Old Apr 9, 2012 | 09:47 AM
ETS Michael's Avatar
The stock turbocharger can only produce "X" amount of power, but you have a few ways of getting there. Some people do the downpipe first and feel huge gains, others do it last and don't feel near as much.
Good Luck
Michael
Old Apr 9, 2012 | 03:25 PM
cragg56's Avatar
Originally Posted by ets michael
the stock turbocharger can only produce "x" amount of power, but you have a few ways of getting there. Some people do the downpipe first and feel huge gains, others do it last and don't feel near as much.
Good luck
michael
+1
Old Apr 14, 2012 | 07:14 PM
jager00's Avatar
Will help more when everything is less restricted. Open it all up dor optimal results
Old Apr 15, 2012 | 11:42 AM
Pbayr0lla321's Avatar
Sounds like your question has been answered but here is my .02
That is correct that $500 is alot of money for a simple 15-20 whp BUT, if you ever drive an Evo X that does have one, you will notice a significant difference in the response/spool up of the turbo. The butt dyno will def tell the difference as well =)
Old Apr 21, 2012 | 04:35 PM
dldjros69's Avatar
Sounds like i need a wide mouth dp NOW!!! lol
Old Apr 21, 2012 | 04:59 PM
AJsGenerX's Avatar
Yes. The.spool is noticably quicker. I gained 15 whp (untuned) with ams intercooler, cobb ic pipes and turbo inlet. Then i tossed grimmspeed ebc, forge bov, and got it tuned. Gained another 16 whp.
Old Apr 22, 2012 | 06:29 AM
steinvb12's Avatar
Try 0hp. I'm not sure why you think an aftermarket DP will get you that much power on the stock turbo.
I saw 2 cars dyno'd and tuned back to back, with the only change in mods an aftermarket downpipe. There was a 0 hp difference between the 2 cars after they were each tuned.
You guys talk about gaining power before the tune, who cares! It's all about the #'s after the tune. Now, if you are running higher boost with E85, or plan to intall an aftermarket turbo, then sure a downpipe will provide hp gains. It's also not a bad idea to do the entire exhaust at the same time if you plan on doing either of those in the future.
I agree there is probably some difference is spool and response, but please stop saying there is a difference in hp with a normal bolt-on car. You are spreading misinformation.
Old Apr 23, 2012 | 05:08 AM
MOREPSiTEHBETT4's Avatar
That's what sheeeee saiiiiid!
Old Apr 23, 2012 | 07:21 AM
dldjros69's Avatar
giggity!!!
Old Apr 27, 2012 | 07:47 AM
