When compressor blades go NOM NOM NOM
Old Apr 26, 2012 | 05:42 AM
AWDTerror's Avatar
Not sure if a piece of weld slag broke off, or something else, but here is what I found, really by accident. Car has been running fine, with no abnormal noises or sounds, and the car still pulls hard and boosts to 25psi without fail.
To make a long story short, I took a picture of the compressor housing while I had the intake off to do a boost leak test, and didn't look at it. 2 weeks later, I decided to delete some pictures off my phone, and was looking at the picture I took and noticed something odd. So I started making preparations for replacing the turbo. I decided to take the intake off to check for material in the I/C and took a better picture of the compressor blades, which is the picture above.
Moral of the story, check your compressor blades on occasion.
Old Apr 26, 2012 | 05:51 AM
ithveno339jfkj4kjekjqqqq's Avatar
oof that sucks...
does the turbo shaft have any play?
Old Apr 26, 2012 | 06:20 AM
AWDTerror's Avatar
Not at all. Probably been like this for thousands of miles.
Old Apr 26, 2012 | 07:29 AM
then you're probably good... those chewed up fins will be more turbulent, so just periodically check the shaft play...
Old Apr 26, 2012 | 07:56 AM
AWDTerror's Avatar
I figured. I have a used turbo coming in and will have it replaced sometime next week. I figured I can use this one as a core for an upgraded stock frame turbo.
What would the affect be on a tune with the blades like this?
Old Apr 26, 2012 | 12:14 PM
GokuSSj4's Avatar
wow!!!! tiime for an upgrade??
Old Apr 27, 2012 | 01:57 AM
mct9891's Avatar
weird, guess it's one of those if it ain't broke, don't fix it kind of things haha
Old Apr 27, 2012 | 02:35 AM
todd6027's Avatar
something got in there
Old Apr 27, 2012 | 11:26 AM
AWDTerror's Avatar
I thought about it, but I don't want to spend the money right now, and plus I live in a very rural part of the mid-west, and don't have access to a reputable tuner. Nearest would be Cobb in Plano which is 8+ hours away.
irmerm
13
May 13, 2011 10:06 PM
furiousd
Feb 27, 2010 06:28 AM
AWDTerror
36
Sep 16, 2009 09:15 PM
PlayinWithFire
Dec 21, 2008 08:09 AM
