Clutch or normal?
Old May 21, 2012 | 06:42 PM
TOAjosh's Avatar
Clutch or normal?
Hey guys When in 4th gear around 3800 Rpms when I floor it the boost spikes to 23psi and the Rpms go up about 300 or less and hold for a split secOnd until the boost tapers back down to 20psi. The car pulls the whole time but sirta sounds like ita slipping but if it is its only climbing about 300 rpms abd for then then a half second. Is my clutch slipping or is this due to boost spike?
Old May 22, 2012 | 07:55 AM
TOAjosh's Avatar
UPDATE: this problem does not occur above 4000 Rpms
Old May 22, 2012 | 07:57 AM
Noize's Avatar
EvoM Administrator
Will it not do it in 5th as well? Might be slipping at peak tq depending on your tune.
Old May 22, 2012 | 11:23 AM
TOAjosh's Avatar
It does but not everytime. I agree about the peak TQ due to the fact it only happens when boost spikes
Old May 22, 2012 | 02:13 PM
Noize's Avatar
EvoM Administrator
Definitely sounds like clutch slip to me. I'd detune just slightly in that area of the powerband only and see if it can long term cure the problem. If not, you're looking at a new clutch.
I had a clutch that slipped at peak tq in my VIII, but it was fine, just torque overwhelming the pressure place.
If you need help tweaking the ROM, let me know. It should be pretty easy.
Old May 22, 2012 | 03:47 PM
TOAjosh's Avatar
Well I have the garbage first gen access port with a 93oct stage 2 map Do you install clutches? Lol
Old May 22, 2012 | 04:55 PM
Noize's Avatar
EvoM Administrator
I got no clutch install skillz, but I can probably help with the tune. I'm out of town until Sunday, PM me if you wanna tweak it after that.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
MitsuJDM
19
Nov 9, 2016 03:47 PM
EVOVIIImadrid
11
Oct 14, 2011 04:42 AM
JamesKrickeberg
Jul 4, 2011 02:36 PM
RobDogg
Aug 5, 2006 04:43 AM
