Is this what old spark plugs should look like?
Old Jun 2, 2012 | 08:17 PM
ugakirk's Avatar
Prolly a stupid question but..I just change my plugs last week. Right before 40k miles because I'm about to get tuned. Is this what normal used plugs look like?
This didn't exactly look right to me..
Old Jun 2, 2012 | 08:25 PM
brenner's Avatar
they look ok to me.
they have some miles on them for sure, but nothing glaring
Old Jun 2, 2012 | 08:33 PM
Anarchy99's Avatar
They look overheated with the brown on the porcelain
xShutYourMouthx's Avatar
looks a touch on the lean side. definatly hot. hense the white on them. I have a set I pulled out after 47000 miles was running a lean code had a hole wore in on the vacuum line to the fuel regulator i will take a few picks for you.
Old Jun 2, 2012 | 08:50 PM
RoMeIX's Avatar
Looks like things may be a bit lean as others have mentioned here, otherwise not bad.
Old Jun 2, 2012 | 08:55 PM
These had 47000 miles on them I belive. Had a lean code prior to the change fix the lean problem replaced plugs. These are only a 7 heat range where yours are a hotter 8 range might be why there a little whiter.
Old Jun 3, 2012 | 02:05 PM
Anarchy99's Avatar
8 is colder than 7. Ngk is higher numbers= colder plugs
Old Jun 3, 2012 | 07:42 PM
RazorLab's Avatar
Looks fine to me over the internet. The "dusting" has nothing to do with heat unless it's so lean there are no deposits at all. Some deposits like you have are normal.
You have to look at the band on the strap to determine the actual heat. Which nobody can see from those photos, so ignore the people saying it's running too hot.
Old Jun 4, 2012 | 11:18 AM
Kracka's Avatar
This.
Old Jun 6, 2012 | 09:58 AM
brenner's Avatar
they just look like plugs that needed to be changed.
i bet the car feels a little better now. colder plugs properly gapped always feel good.
ugakirk
Jan 1, 2022 10:07 AM
ugakirk
For Sale - Wheels / Tires
Apr 23, 2013 06:00 AM
ugakirk
Mar 23, 2013 10:13 PM
ugakirk
For Sale - Cars For Sale
23
Oct 21, 2012 01:25 PM
ugakirk
Dec 6, 2011 03:05 PM
