Low Fuel Pressure - I'm LOST!!!!!!
Old Jun 16, 2012 | 07:00 PM
Octane Blue's Avatar
Well I changed my filter on my fuel pump with a new one and I'm still having the problem.. :/
How do I check voltage at the fuel pump like some of you have suggested?
Old Jun 17, 2012 | 05:30 PM
bump
Old Jun 18, 2012 | 11:15 AM
Anyone?
Old Jun 19, 2012 | 11:11 AM
bump
Old May 13, 2013 | 03:04 PM
The-Evo's Avatar
Hi, did you ever figure it out? I am having the same problem. When I start it up the fuel pressure is around 40psi. After the car is warm and I drive it for a minute, the fuel pressure drops to 25-30psi.
Old May 13, 2013 | 03:42 PM
momostallion's Avatar
i believe this is normal. when the car starts up the fuel pump runs max voltage then after a few seconds switches to low voltage mode. the map referenced is load vs rpm, so i'm guessing this is the trigger point here OR there is a time based fuel pump voltage map used for starting the car. either way, no worry.
i will say however, 25 psi seems on the low side.
base fuel pressure stock is 3bar (43.5 psi). this should be set without vacuum. so after vacuum is applied through a 1:1 regulator (approx -11 psi). you should be around 32 psi theorotically but typically it seems to work out around 38 psi.
Headtrauma89
Apr 7, 2017 09:42 PM
mrfred
58
Jan 4, 2016 06:09 PM
deza3000
Oct 4, 2015 11:09 PM
Liqquid
10
Aug 13, 2013 07:07 AM
Beeble
Mar 23, 2011 03:15 AM
