Low Fuel Pressure - I'm LOST!!!!!!
Old Jun 13, 2012 | 09:08 PM
Octane Blue's Avatar
When I first start my car up, it hits the 40ish base pressure that is normal... Then after I wait around 8 seconds or so it immediately hits 27ish psi..
My vacuum reads as normal as it did before.
I think it's able to hit the correct base pressure when I first start it because the fuel pump primes it up better or something..?
Here's my setup -
Boomba Fuel Rail
Fuel Labs Gauge
OEM Fuel Pressure Regulator
Aeromotive 340 in the tank
FIC 1100s
Here's the worst part - I was personally invited to have my car in an airshow for a little bit this weekend and now I'm thinking I may not be able have it running correctly by then
Please Help. Any advice is appreciated.
Old Jun 14, 2012 | 09:31 AM
Bump
Old Jun 14, 2012 | 01:20 PM
AWDTerror's Avatar
Check your voltage for your pump. Most of the time we have a problem with high fuel pressure.
Old Jun 14, 2012 | 01:30 PM
evo 9 guy's Avatar
Or maybe a bad pump???
Old Jun 14, 2012 | 03:46 PM
Anarchy99's Avatar
Add an aftermarket fpr
Old Jun 14, 2012 | 03:49 PM
SFL Autosports's Avatar
make sure when the pump installed the rubber grommet is still in between there and the pump hasn't slipped out
Old Jun 14, 2012 | 04:12 PM
AWDTerror's Avatar
You need to eliminate all possible other issues first. If anything his fuel pressure should be super high.
Old Jun 14, 2012 | 05:16 PM
Will do. So it should just be at 14ish volts, correct?
Hope not, it's brand new and was working fine before.
K, give me the money and I'll go do that and find out it was something else.
Can you expand on this please? Sorry, I have a pretty bad memory of what everything looked like when I installed it.
Thanks for all of your replies.
Old Jun 14, 2012 | 09:39 PM
louiesevox's Avatar
Have u checked the small filter in the fuel pump assembly? It might be clogged, there for reading normal during the initial prime then dropping alot due to it being clogged.
It might not be the issue but it wont take longer than an hour to check...
Old Jun 14, 2012 | 10:34 PM
hotstix's Avatar
Also double check the vaccum line running from the intake mani to the FPR, and ziptie it on there if you havnt already.
Old Jun 14, 2012 | 10:52 PM
When I pull my pump out tomorrow to see my voltage I hope it's just the filter too. Thanks for the extra confidence!
I have it zip tied. Thanks for the advice!
Old Jun 15, 2012 | 01:32 AM
hotstix's Avatar
Have you replaced your fuel pump relay?
Old Jun 15, 2012 | 07:09 AM
Contact me and i'll run you through it
Old Jun 15, 2012 | 08:21 AM
I checked it. I swapped it out with my headlight relay and it works just fine.
How late are you guys open?
Old Jun 15, 2012 | 12:43 PM
hotstix's Avatar
hhmmmmm, I would recommend chanigng it out if you have the old style black one in there. That would be a good starting point.
