injectors and fuel pump, decisions decisions
Old Aug 20, 2012 | 01:43 PM
EDM92's Avatar
Originally Posted by Inprogress
Between the walbro and DW65, which is the better option?
+1 and why
Old Aug 21, 2012 | 08:29 AM
elim0's Avatar
sorry to hijack the thread op but i was wondering similar thing.
i have a evo8 w/ 9 turbo w/ 20g housing, full bolt ons, cams, - would i even need bigger injectors ?? --- i am running pump gas 98 (as i live in aus)
also did you mention we dont need to change/get a fuel filter? (i think i've read that somewhere before, is that true?? )
thanks guys !
Old Aug 26, 2012 | 07:58 AM
chriswolf81's Avatar
Originally Posted by EDM92
+1 and why
I have the FIC 1100 and the DW pump. They are a great match, as I think they would run out at the same time.
ID1000 and walbro255 are a great match also.
The difference is that the DW can run a bit more fuel and is much quieter, since it uses a turbine. The walbros are sometimes referred to as winebros, as they make quiet a bit of noise. DW is not noticeable at all.
Further they are identical size and utilize the same install kit and you only pay a lil more for the pump.
Both setups will support 450-500whp on E-85.
Sometimes a tuner prefers a certain injector type, so always good to ask. 3-ports are reasonable and a must in my eyes if you are modding already. Go for the GM or Grimspeed.
Old Aug 29, 2012 | 10:56 AM
EDM92's Avatar
Sweet, thanks for the response!
Old Aug 29, 2012 | 11:44 AM
jyamona's Avatar
DW65C + ID1000's. that's my setup and I couldn't be happier. The pump is quiet and flows well. I'm in the process of having my EF3 tuned....currently at 420whp and plenty of IDC to grow!
Old Aug 30, 2012 | 12:11 PM
kindawg's Avatar
I have the DW 65c and the FIC 1100cc injectors, my tuner was able to scale them no problem, work great so far.
Old Aug 30, 2012 | 08:11 PM
busky2k's Avatar
Ditto. DW65c + ID1ks here. The DW pump was easy to install and quieter than the stock pump.
Old Aug 31, 2012 | 09:47 AM
rrkpitt15's Avatar
I would not get the PNP adapters. I bought my PNP adapters NEW about a year ago and one day when i started my car it sounded like a subura and i got 2 CEL. So i disconnected and reconnected my injectors and adapters then the car ran fine. When it did this a second time about 2 weeks later, i just soldered the adapters to the stock harness. After i did this, my AFR during WOT went up .3-.5.
If the PNP adapters lose connection during a WOT run, say bye bye motor and say hello to a window in your block.
Are you willing to put the safety of your motor in the hands of a $45 dollar injector adapters?
Old Sep 6, 2012 | 01:17 AM
imdrax's Avatar
Im not sure why nobody has posted about direct install bosch ev14 1000cc injectors on this site. I just installed them and so far not a single issue. they came with a flow sheet, all the latencies, and they dont require a harness adapter, they literally plug right in. for the price i dont think you can beat them
http://www.ebay.com/itm/270895639776...84.m1439.l2649
maperformance
178
Jun 16, 2017 08:40 AM
maperformance
EvoX 'For Sale' External Engine / Power
109
Feb 9, 2016 09:09 AM
maperformance
589
Mar 6, 2015 07:38 AM
Mikami
Sep 27, 2014 05:28 PM
maperformance
Oct 10, 2013 07:25 AM
