Intercooler piping
Old Jul 16, 2012 | 07:28 PM
NVmeSTI's Avatar
Intercooler piping
Anyone know anything about the weapon r icp? i like the look but hows the performance.
Old Jul 17, 2012 | 05:37 AM
mac11wildcat's Avatar
all dimensions the same, all hard pipe kits should perform roughly the same, the same way cat backs would; not many secrets to making a pipe go from one outlet to another. look for a kit with the most gradual bends if you're worried about the minute hp gains or the small difference in spool between each kit.
Old Jul 18, 2012 | 05:37 PM
NVmeSTI's Avatar
Ok thank you so do you think its a good buy?
Old Jul 19, 2012 | 04:28 AM
if you like the look and you havent found anything bad on these forums about them then why not? as long as the price isnt high id say go for it. im not familiar with them unfortunately. just for clarification is this an upper or lower ICP?
Old Jul 19, 2012 | 08:20 AM
NVmeSTI's Avatar
Its upper and its about 270 dollars the whole upper and lower is 630
Old Jul 19, 2012 | 10:19 AM
if m not mistaken not much is gained from an UICP. all the hp and spool gains are seen in the LICP. if you like the look then by all means but if youre looking for bang for buck you can do better.
Old Jul 19, 2012 | 10:31 AM
sith_killer_99's Avatar
With the Evo X, best performance gains are from an upper pipe, Evo VIII and IX get best gains from a lower pipe. It has to do with the way they are set up.
OP, if you are looking for a good set for a great price, try COBB. They use a weld free, mandel bent, single pipe setup, and the list price is $595 for upper and lower.
http://www.cobbtuning.com/Mitsubishi...X-p/752550.htm
Old Jul 19, 2012 | 11:04 AM
Kracka's Avatar
I don't have Cobb's kit, but the features you mentioned are very important to me, plus aluminum, I don't do steel intercooler pipes. The less welds and couplers there are, the less chance there is for a boost leak plus less internal turbulence for smoother flow.
Old Jul 19, 2012 | 12:51 PM
evo_xtc2011's Avatar
I have the Cobb IC piping, and it's a great piece of work! It does cost alot, but the install was damn near perfect and had no problems at all with it so far.
Old Jul 19, 2012 | 12:58 PM
SOUL STEALER's Avatar
Low coupler quantity is awesome. So much less to worry about when couplers and clamps need replacement due to wear and tear. I had an STI with a Perrin front mount kit. Absolute nightmare that required over $100 in replacement couplers and t bolt clamps every year.
Old Jul 19, 2012 | 01:00 PM
Kracka's Avatar
Another thing to watch for is mounting brackets, these will help prevent couplers from blowing off and to avoid excessive movement which could damage other components. I've been noticing lately some of the cheaper pipes on the market skipping the brackets. Not only is it less time and materials to create, it's less R&D since fitment doesn't need to be as exact.
Old Jul 19, 2012 | 01:45 PM
Yeah, the COBB kit is a no brainer for me.
1. Aluminum construction
2. Powder coated finish
3. Single pipe
4. Mandrel bent
5. T-Bolt clamps
6. Fits with the STOCK air box
7. Mounting brackets
8. 2.5 inch diameter
9. BOV piping from cold side maintains stock location
10. One of the least expensive kits on the market at $595 for both upper and lower.
On a side note, COBB also offers 10% military discount on their products, so $536 and since I am close I should be able to just pick it up on site (no shipping).
I have yet to see a better set of pipes.
Old Jul 19, 2012 | 02:52 PM
NVmeSTI's Avatar
Ive heard that to but im looking for look for upper and performance for lower. Any idea on lower piping?
Not to expensive
Old Jul 19, 2012 | 08:02 PM
BaumBizzle's Avatar
Weapon r is crap, I've had numerous of their parts from my Acura/Honda days and every time it was either fit finish or drone sounds. Quality is crap but those nei chrome pipes do look slick
Old Jul 20, 2012 | 09:20 AM
NVmeSTI's Avatar
So your saying not to get them?
I want something nice but not to expensive. You ever use ETS? And what website do you get your parts off of
