Short Throw Questions
Old Jul 19, 2012 | 05:34 PM
jcnel_evo8's Avatar
Lightbulb
Referencing these Videos:
Starting around 0:15:
Starting around 1:45:
When short throws can get something like those, then I'll switch over.
Speaking to the OP topic, if I had to choose a short throw, I'd go with the WORKS.
Let us know which one you like.
Cheers,
~j.
Old Jul 20, 2012 | 10:46 AM
jt8217's Avatar
So I ordered the WORKS shifter, Blackline Matte Titanium Weighted Shift Knob, Torque Solutions Shifter Bushings and WORKS cable bushings. Everything but the knob is coming from MAP.
I'll let you guys know how the install goes.
Old Jul 30, 2012 | 07:20 AM
jt8217's Avatar
So I got my new setup installed last night. I installed each part and did a test drive between to see how positively/negatively it changed the shifter feel.
When I get a chance later today I'll post my thoughts and pictures.
Did anyone get a more severe lockout when they switched to a short throw? Until it's warm I can't get into any gear with the car on without messing around with it for 30 seconds.
Old Jul 30, 2012 | 08:02 AM
jyamona's Avatar
I noticed that a little bit
Old Jul 30, 2012 | 08:26 AM
Snakes709's Avatar
sand down the pins the bushings go on. I had the same issue with my twm kit and i called them up and they told me you really have to sand the 2 pins down for it to be nice and smooth.
Old Jul 30, 2012 | 08:32 AM
jyamona's Avatar
the ones with the lock washers on the end? I don't see how that would make a difference...
Old Jul 30, 2012 | 10:20 AM
jt8217's Avatar
I can understand for the metal bushings and I may have to do this on the larger horizontal one, but the urethane WORKS cable bushings utilize the factory plastic clip that the pin is in contact with. I'm gonna pull it all off and use some additional synthetic gear/suspension grease. I sprayed some white lithium grease on them, but it may not have been enough.
Old Jul 31, 2012 | 10:24 AM
Kracka's Avatar
Zero lock-out for me. Everything has been installed and working perfectly for over 2 years/40k miles now. I keep my tranny fluid fresh generally changing it twice a year and I think that helps keep things feeling great.
Old Jul 31, 2012 | 11:56 AM
Rmeister007's Avatar
I have the Works SS on my MR and shifting greatly improved. Hitting reverse is kinda hard though sometimes. My friend says that if my knob is heavier, shifting would be even easier. Is this true?
Old Aug 3, 2012 | 08:14 AM
BuyBlackline's Avatar
jt8217, please post some installed pictures of the new setup!
Old Aug 3, 2012 | 08:15 AM
Kracka's Avatar
Sometimes; my IX transmission liked a heavy knob but my X and S2k transmission did not. It's worth a try if you have access to one.
Old Aug 4, 2012 | 02:13 AM
yngwie24's Avatar
Who else has a TWM short ****er w/ full cage replacement?? i recently installed mine and it's leaning to the right. Is that suppose to look that way?? coz if anything it should be leaning to the left closer to the driver right?
Attached Thumbnails Short Throw Questions-2012-08-04_01-20-15_913.jpg   Short Throw Questions-2012-08-04_01-33-19_382.jpg
Old Aug 8, 2012 | 11:23 AM
fostytou's Avatar
EvoM Community Team
Maybe since the bend goes toward that edge it leans the other way to make sure it clears? I'm not sure, just offing a possibility.
...or maybe its a JDM/RHD model?
Old Aug 9, 2012 | 04:48 PM
m0nkie's Avatar
hmm.. I thought TWM specifically said theirs do not lean to the right...
mine just arrived today, I'll install it this weekend and see how straight it sits..
Old Aug 9, 2012 | 05:41 PM
yngwie24's Avatar
good luck bro they had to replace mine.... smdh...
